Damn my CFI expired... options???
SIG600
dang my CFI expired... options???
I completely forgot my CFI expired in Sept of this year, it just dawned on me driving to work the other day. Are there any options for renewing it (CFII/MEI)???
Edit: Searched.. so if I'm understanding this right (don't have a current copy of the FAR's)... I just have to take anyone of the Practical Test check rides again, and I'll get back all three?
You are understanding it right.
If you are online, you do have a copy of the current FAR.
http://ecfr.gpoaccess.gov/cgi/t/text/text-idx?&c=ecfr&tpl=/ecfrbrowse/Title14/14tab_02.tpl
The one you want is 61.199.
§ 61.199 Expired flight instructor certificates and ratings.
(a) Flight instructor certificates. The holder of an expired flight instructor certificate may exchange that certificate for a new certificate with the same ratings by passing a practical test as prescribed in §61.183(h) of this part for one of the ratings listed on the expired flight instructor certificate.
Your only option at this point is to give a call to the local FSDO. They'll either point you in the direction of a DPE that can reinstate you, or they'll set you up with an appointment so the feds can do it. Plan on a 1.0 to 1.5 checkride and probably an oral.
I was in this situation several years ago, although I was out of instructing about 2 years. Went to DPE, the whole thing took about 3.5 hours, Oral + Flight. The whole visit was kept positive with emphasis on recent changes. Not really a "test" atmosphere. But I would (& did) still brush up on the book material, especially the sign-offs. I would recommend to go to your FSDO, it's free & I've had good experiences with the FSDO recently.
I once was in this situation and asked the DPE what the difference was between reissue and reinstatement. His answer "the box that you check". If you find the right DPE this will be a non issue. You may ever find a Fed who will just write you out a new certificate based on you being current and a professional but with a lapsed CFI.
pts
if you look in the cfi pts it shows the required manuevers/oral etc. for a reissue
I just renewed mine....no way am I going to take another CFI ride....
Nice quote EMBATP.......Airport '70???
Reinstating CFI
I just did reinstate my CFI's this last summer.
1. The reinstatement flight test has different required tests from the original issue tests. See the flight test guide.
2. Decided to reinstate my CFII because current instrument pilot but last CFI work was 10 years ago! CFII tasks much easier. Reinstating ANY of your CFI's reinstates ALL your CFI's. I took the CFII flight test and got current CFI,CFII, and ME-CFI.
3. Dont ask your local FBO flight school about the process. Checked with two local and got two different (WRONG) answers. I checked with American Flyers (Ft Worth) because I was a student there many years ago. Got the right answers, help, and schedule of an examiner who worked with the school who was qualified to do reinstatement and knew how. Both he and school had done this process before.
4. Spent some bucks on ground school finding out that lots of things had changed since last I was a CFI / CFII. I thought the money was well spent.
5. Hardest thing was compass turns! Had not done them in YEARS! Well, also hadnt flown a C-172 in years either. Much different response to 727,737, or 767<g>.
6. Take the online recurrent training every two years and dont let the CFI stuff expire!!!!!!!!!!!
Good Luck
Phil Bailey
Son of a #%@#$^!!!!
I just looked at my certificate to see when mine expires.... Aug 31,2006.... oops.
Anyone know a good DPE in the MKE area?
I'll second the request for a good DPE around MKE. Mine expired about a year ago.
try Al Englehardt (sp) out of the pwk area. Back in the day when I sent him students, he did a bunch of airline and military cfi/atp's and he was real world and fair. United guy that has flown the whole line of equiptment.
Try google and search for him.
How do people forget when their CFI expires? As the date comes close, your mailbox will be full of junk mail from all the FIRC companies advertising their stuff? That's how I remembered that mine was about to expire.
I reinstated mine by just asking my POI to reinstate it during my 297 ride. I talked him through a steep turn, a stall, and a landing and that was it! Easy money.
If you're flying for a certificate holder, a lot of times the FAA will shoot you a reinstatement with a recurrency, or will handle it over the counter at the FSDO as courtesy. However, barring that you're looking at reinstating it.
You don't need to do a checkride for one of the ratings on your certificate...you can do a checkride for a new rating, and still reinstate the old ratings, too. For example, if you don't hold flight instructor privileges in a glider, you can go do a glider add on to your instructor certificate, and passing the practical test for that add on will reinstate your certificate. If you're going to spend the money, why not get something new and perhaps learn something in the process? If you don't have instrument priviliges for instruction...go do the CFII...that is as good as a reinstatement ride, but you get more bang for your buck. You see my point.
I've let mine expire twice over the years, and have found it's easier and less expensive to go with renewals, than reinstatement. It does creep up on you...but then I've seen a lot of pilots run right up to the last day on their medicals before the alarm goes off and they're rushing get it done...if you're not using the CFI, it's easy to forget.
With Sport Pilot and a host of other changes that have taken place, a lot may be new or different from the last time you reupped the CFI. Even the basic teaching concepts have had quite a facelift over the last year or two. Getting some recurrent isntruction before reinstating the certificate isn't a bad thing.
Liar! this guy is a messed up ass!!
During the last three months my instructor certificate was current, I interviewed and got a new job, went through training to learn a new aircraft and new 135 op specs, moved across the country, and discovered my wife was pregnant. Its not that I forgot about renewing it, I just had more important things on my mind at the time. I think thats how most people end up letting it lapse.
