Cubonaut875
- Jul 4, 2023
- CCX-2000 FX3
- 3MY
- Private SEL
Very very sad. You better be carrying a spare coil pack. Today again was a day this would have found me 1.5 hours away from home just like the last time, in almost the same location I flew 6 months ago when this happened on the way home.
Yes. And in the YouTube video I watched yesterday he tipped off that Klaus (Light speed) makes the spark plug wires. We are supposed to change them every 500 hours. I'll email Klaus to see if he makes them for my plane and if so how much as I have a feeling it will be significantly cheaper than the $486 on the CubCrafters store. Okay, I deleted what I was going to post and leave this where it is. Be smart with your shopping both when buying the plane as well as components after. Nuff saidDid you get your spare coil pack from LightSpeed? Made the mistake buying the backup ignition battery from CC. Never again.
The problem here is you don't know where they got them from. They could have ordered from Amazon in bulk as well. Consider buying from an authorized distributor in the future just to be safe but I learned a bigger lesson of resistance testing new plugs before they go in your plane.Great info, I got my spark plugs directly from Cubcrafters, they were$13.36 a plug, so they are more expensive from Cubcrafters.
I emailed Klaus to see if he makes them and the cost. I also added the parts required to make them myself to my Amazon cart, all MSD branded wire, 90 degree crimps, crimp tool, and doing it yourself would cost the same or more than just buying them pre-made. As it's not something we change often I don't see going down the DIY path but if my coil pack issue continues and my next step is replace some of the spark plug wires then it may be something I pursue to replace some, not all, of the wires, i.e. right ignition side only.Yes. And in the YouTube video I watched yesterday he tipped off that Klaus (Light speed) makes the spark plug wires. We are supposed to change them every 500 hours. I'll email Klaus to see if he makes them for my plane and if so how much as I have a feeling it will be significantly cheaper than the $486 on the CubCrafters store.
Wow!!! CubCrafters wants $91 for the PS-1221S battery?Did you get your spare coil pack from LightSpeed? Made the mistake buying the backup ignition battery from CC. Never again.
Did you regret due to cost or quality?Did you get your spare coil pack from LightSpeed? Made the mistake buying the backup ignition battery from CC. Never again.
Ha - I was 99.9% sure of that but I just had to check. I replaced my ignition back up battery at my last condition inspection, of course it should be replaced every inspection, from what I understand, and of course was not at my previous inspection at the authorized Cub Crafters repair facility. So I guess I'm even on overall cost of ignition batteries since I paid 100% more for the most recent replacement.
You may need your transponder firmware updated. It's the one thing we can't do ourselves.
I have not seen the issue with the ADS-B showing the message in yellow (NO ADS-B) or whatever it was since updating the firmware to the transponder and ADS-B. Maybe it fixed this issue. About to replace the coil packs again, but point is they are the same so maybe it wasn't the cause and the firmware was.I am seeing the same issue on the GNC 355. It seems to appear more often when there is no other traffic anywhere in range (Canada does not have ADS-B ground stations like the US so I get weather, notams, etc. via SirusXM). I wonder if there is a shielding issue on the Ethernet connection that makes it sensitive to electrical noise?
I have the GTX 45R and the firmware update is possible as the windows software to update it via USB (USB connector is under the panel just behind the USB power) is available on the Garmin site. I need to install a Windows VM on my MacBook Pro and see if the USB will connect.
