Cubcrafters CO levels with belly pod
BiggieN143AE
1994 Beech A36, Cubcrafters FX3 on order
93C
Private, Instrument
I have a FX3 with the Carbon Concepts cargo pod. I get higher than desired CO levels on the Garmin G3X during all operations but cruise. I do not get them on my Lightspeed Headset. Also get smoke from smoke system if I hold that on too long. Cubcrafters says it’s the pod causing air disturbance- any other thoughts/experience? I have sealed every crack Neal recommended in the posts on calibration of the detector earlier
I have no issues with CO. I sealed the gear leg area which is where much comes in. I calibrated my CO detector. Also check the Aithre app, if that's your detector, and that's your true number. I fly with 0 CO typically after sealing things up.
