CRJ700 max pilot case dimensions
I HATE HATS
Member
Does anyone off the top of their heads know the maximum dimensions for a flight case in the CRJ 700 (you know, to fit in the slot next to the "refrigerator")?
Thanks.
It holds a regular flight case, but most of the fancy ones with pockets or wheels won't fit.
I have the Ballistic Flight Kit (at the bottom of the page). It's 14" x 19" and fits as long as a minimal amount of stuff is in the outer pockets.
The ballistic is actually 8 x 19. The 14 is the height and does not matter as to whether it will fit or not. I used to use one and if you put anything in the outside pockets it won't fit... also after a while the bottom pocket corners get turned out and get in the way when putting the bag in, it got very annoying after a few years with that bag. I switched to a plain vinyl case with no pockets and it just slots right in there!
