Wingspand is bigger on the CL65
CL65 69ft
Cl600 series 65 ft
Length stretched 19 ft
Just like the G-200 has the same wing as the G-100 with an increased-sized center section, the CL-65 has the same wing as the 600-series Challengers with a larger center section (which gives the added wingspan). In other words, they bolted the wing of the Challenger on a new wing center section for the CL-65. So they do have the same wing (sort of).
Technically, the wing of the CL-65 is a Candair 13.2% airfoil (at the root) and the wing of the CL-600 series is the Canadair 14% airfoil. Both aircraft have the Canadair 10% airfoil at the tip.
Source:
http://www.ae.uiuc.edu/m-selig/ads/aircraft.html
