Yeah, I tried to double-quote in the post but I ain't so computer savvy. Forgot to say in the original post, but reposted that the packs were on the APU.
Was the temperature in the FMS exactly on 10c, if it was the aircraft will not generate a thrust setting with the anti-ice on and the temp right at 10c, even though the books say 10c or less. Next time try putting 9c in the box and that will fix it!
If you put in a Flex Temp it will kick out the carrots when you select the cowls on b/c you're not supposed to flex when you're using anti ice protection. Make sure you select full take off numbers when that happens.
Did you try a different temperature (lower)? I forget how it works in the -200, but sometimes the FMS in the -700 won't take a flex temperature if the OAT is too high, we just put a lower one in until it works, the Fadec takes care of the normal thrust settings so this exact problem can't occur. Sorry for the bad advice based on a different airplane, but what the hell, this is Flightinfo, right?
It's been several months since we had to use the cowls on the ground for T/O. It was cold and rainy yesterday, and when they were selected "on" with the bleeds on the 10th for the packs the T/O carats would go away. We went to the perf page and selected all of the options. Is this normal? I read the POH and couldn't find much info. We had a long line before we could launch and tried some other things, but couldn't solve the problem. Any help is much appreciated.
Does it scare the crap out of anybody else that somebody would come to flight-info for specific aircraft operating procedures like this rather than just contact their company fleet manager? I don't fly the CRJ so I have no clue if the advise given to date is accurate or not. But I'm sure procedures vary from airline to airline and a better choice would be to ask your own training department.
