PoorJetDriver
- Aug 18, 2004
So one engine was shut down then the T handle was pulled on the other? I'm not a CRJ driver, but I'm assuming it has engine driven and electric hyd pumps. Pulling the T handle on the only operating engine would shut off the single running engine driven pump and would it take the gen off line which would fail the single running electric pump? Now you have no hyd pressure at all? No brakes or emergency brake.
Hi.
Update. Talked to someone who knows Jetlink pilots:
On takeoff, both engines accelerated to max power. Takeoff OK, but then what to do? They shut one engine down with the emergency shutoff (T-handle, or whatever they call it), and successfully landed the plane on one engine at 100%.
Taxied back, and chocked in parking spot. Engine still at 100%. Could not shut it down. Then brakes gave way, as overheated, jumped chocks, and smashed into building. Capt and FO OK...Only broken leg and broken ankle.
I injured pax was killed on way to the hospital in ambulance, and I heard from other posters; 2 other persons outside ambulance killed in ambulance accident.
cliff
NBO
