USAFftrplt
- Apr 11, 2003
Having flown both the CR7 and the E170 as a pax I have to say there is no comparison. The E170 feels like a mini Airbus and it is far more comfortable from a pax standpoint - bigger bins, wider cabin with much more comfortable seats, huge windows that don't require you craning your neck down and bigger lavatories. Plus, the E170 flight deck is way more advanced (Primus EPIC).Treme said:I dont have too much as a basis for comparison. The only other pure-jets i've flown have been the DC9, the 737-300/400, and the CRJ200.
My first impression is that it's still an RJ. It does have significantly more power (and more importantly better air conditioning) than its smaller sibling.
The airplane has relatively poor flying qualities. It still has rather large pitch excursions with flap/slat extension unless you slow to min maneuvering speeds prior to selection. (can't do the "slats and 5" trick like we did on the 9'). Selection of flaps 20 over 210 does seem to create a big rumble. In other airplanes i've flown you could avoid uncomfortable use of the speedbrakes by configuring with slats and a few degrees of flaps. In the CR7, unfortunately, that is every bit as uncomfortable as just using speedbrakes. Disapointing.
It is somewhat sloppy at slower speed. I dont know whether this is a problem with the artificial feel or the multifunction spoilers, but this isn't so large an aircraft that the lag time between control imput and aircraft response should be that significant (in roll). The DC9 -- with no hydraulics save the rudder -- had virtually instantaneous response.
The pitch attitude on final is certainly an improvement, but still lacks in the flying qualities in landing configuration that the 9 and the 737 had. Maybe it just takes a little getting used to. I havent been flying it all that long.
The FADEC is certainly a nice change but, sadly, the airplane still tuckers out in the mid-20s to around 1000 feet per minute. In order to manage energy and climb at .74 in the higher altitudes, you just cant let the thing get slow. As a result you lose a lot of climb performance. It's not as bad as the 9' and certainly is a thousand times better than the 50 seater, but it doesnt hold a candle to the 737 (and, I assume, the 727, 757 etc.) when it comes to mid-altitude climbs through the mid-20s and low 30s. The 737 would hold at least 1500 fpm through FL290 and maybe 1000 fpm above that. It was rare to see it fall below that (in VNAV climb) until you were passing FL350.
Bottom line? It's still an RJ. The customers dont like climbing the stairs, the overheads are too small, and they still use the cheap seats with very little padding. The product is not at all competitive with the E170 and certainly not with the larger mainline airframes. Its one saving grace is the lack of middle seats.
Companies that fly the CR7 and CR9 could make improvements which would MAKE it more competitive (jetways at EVERY station, XM radio at each seat, better seat quality, light snack service on flights in excess of 2 hrs) but I sincerely doubt they will spend the $$.
Just adding my opinion to the mix.
1000 fpm @ mach .80, maybe. I climbed out at 250 knots to .74 once (bombardier's actual best climb speed) and we were at 1500 fpm, at 72000# (73000$ t/o weight) and FL290. Even the subscribed 290 yields better than 1000 fpm in the 20's, although it does tucker out a bit, but still above 1000fpm if you manage your engergy correctly (not hard to do). What it loses in the upper 20's it gains back in the lower 30's, fadec scheduling, I suppose. M .80 cruise is no problem from 310 to 350 unless ISA gets above +15. The 85.3 limitation is what kills your cruise in the upper 20's, but that's supposedly fixed and we're just awaiting the change in procedure.Treme said:The FADEC is certainly a nice change but, sadly, the airplane still tuckers out in the mid-20s to around 1000 feet per minute. In order to manage energy and climb at .74 in the higher altitudes, you just cant let the thing get slow. As a result you lose a lot of climb performance.
What about compared to the Challenger 604? 601?328dude said:All three have the same type rating. Just have to go through 4-5 days of differences training.
328dude said:I asked Bombardier that same question. They have a program to go from the 601,604 to the CRJ, as well as the reverse.
It's a two week program, with a type ride. They are diffrent types.
