Oakum_Boy
supercalifragilistic
- Nov 10, 2003
A Master warning triple Chime, "Bleed Air Duct" Aural Alert, w/ a red 14th Bleed Warning messege.
Wrong! Dork!
Sure it is. The bus fault kicks the onside gen, and the little bus tie light thingy turns on to tell you it didn't connect to the offside gen, therefore it's isolated.
Not automatically, it's not.
How do you turn the water off to the galley and toilet if there's a leak in either system?
Dork's are cool
How about the coffee maker when it starts leaking water and not making coffee. Is there a valve behind the containers that can be turned off?How do you turn the water off to the galley and toilet if there's a leak in either system?
Dork's are cool
