aftrburner
- Nov 16, 2004
aftrburner said:This may not be the proper forum but which engine is the critical engine on the B747?
Thanks.
Eh, wouldn't it be #1 or #4?T-REX said:The upwind #2 or #3 engine. What do I win???
mrnolmts said:Eh, wouldn't it be #1 or #4?
Thanks.
Uppercrust said:What is the critical engine of an F-16???
Junkflyer said:They're all critical on a 100 flying out of the Middle East in the summer.
stupidpilot said:The critical engine is more of a prop term because the propwash over the wing surface provides alot of the lift on that wing. So when you lose an engine on a twin you lose 80% of the lift not 50%. But a jet engine does not provide lift to a wing so its not as big of a problem if the aircraft was designed with sufficiently powerful engines. Even on 2 engines the DC-10 still climbs like a raped ape if its not too heavy.
Critical engine is more for props
GuppyWN said:I'm not sure but I do know if you lose one right after takeoff in SFO the car alarms sound for miles!
Gup
