turbosheep
New member
- Jan 24, 2005
You can get a type rating on a PPL, you don't even need to have a CPL. It's actually not all that uncommon - you just have to have the $$$. Back when I was flying a Lear there was a guy come through for a VFR Lear type on a Private certificate - now what's the point with that???turbosheep said:Hello,
Appreciate any help on the question below:
Can a CPL holder be PIC in a multi-engined jet aircraft with a MTOW above 12,500lbs?
The aircraft is to be operated under FAR91 ruling (non-fractional).
If able/unable, where can I find the reference?
Thank you.
turbosheep said:What I meant was, is holding a CPL good enough to operate a multi-engine jet above 12,500lbs as PIC?
mattpilot said:you only need an ATP cert once you get into Part 121 flying as a captain...
You only need a CPL if you are doing commercial flying that is not requiring an ATP cert.
Everything else can be done on a PPL.
