pilotlbs said:Any one know if you can decifer mountainous terrain from non-mountainous terrain on a low altitude enroute chart?
What is the difference between a shadowed navaid identification box vs. a non-shadowed one vs. no box at all?
Thanks folks.
CaptETWes said:Shadow box navaids are ones that are part of a published airway. This includes VORs and NDBs. Conversely, off-airway navaids are unboxed. Not sure what you mean by a non-shadowed box, however; someone else can answer that. I can't say that I've seen what you are referring to here.
Thanks for the reply. Yeah I've read the legend a couple times and unfortunately that's what leads to the questions sometimes. Check out Pg. 57 of the introduction, I don't know if they'll be the same. Anyhow on the right side, middle of the page is what I meant by an un-shadowed box. It says VOR (Off-Route), but in the legend I don't see something referring to that. I just see what you had said up there about non-boxed being off airway. Thanks again. Oh btw, the reason I ask about the mountainous terrain on the Enroutes is because I saw it on some gouge, but I've never known you could decifer between them or if you even can.
time builder said:There is a more precise answer, something to do with being west of the Miss. with the exception of the Central Valley in California.
Well, having tried to cross from Kansas into Missouri around the St. Joseph area with 600-ft ceilings, it sure seemed like it at the time!A Squared said:So, Iowa, Kansas and Nebraska are mountainous?
microbrewst said:mountainous terrain = 3000ft change in 10nm OR above 5000ft MSL
