Converting to FAA
bosshog
New member
G'day guys,
I'm a brand new member and has recently moved to a country that recognises the FAA licence.
Although I'm not Canadian (good or bad i don't know) I do hold a CPL and multi IFR, for Canada.(plus CPL and CFI for another country too)
I was wondering if i have to sit a CPL flight test and Instrument or can I just convert automatically like what you do for the PPL.
Thanks for your help
bosshog.
I haven't had to deal with this for a few years, but it seems that you can get an FAA private license issued on the merits of a foreign license without a written test or check ride, but for a Commercial or ATP you'll have to do the written and the ride.
Maybe someone else has more current info.
Foreign license conversion
It's been a few years for me, too, but I agree with the above. You can go to the FAA with your foreign (to us) commercial license and be issued a U.S. Private certificate.
You probably need to take the U.S. writtens and a flight test(s) to obtain U.S. commercial and CFI certificates.
14 CFR 61.75, below, spells it out for you:
Sec. 61.75 - Private pilot certificate issued on the basis of a foreign pilot license.
(a) General. A person who holds a current foreign pilot license issued by a contracting State to the Convention on International Civil Aviation may apply for and be issued a private pilot certificate with the appropriate ratings when the application is based on the foreign pilot license that meets the requirements of this section.
(b) Certificate issued. A U.S. private pilot certificate that is issued under this section shall specify the person's foreign license number and country of issuance. A person who holds a current foreign pilot license issued by a contracting State to the Convention on International Civil Aviation may be issued a private pilot certificate based on the foreign pilot license without any further showing of proficiency, provided the applicant:
(1) Meets the requirements of this section;
(2) Holds a foreign pilot license that --
(i) Is not under an order of revocation or suspension by the foreign country that issued the foreign pilot license; and
(ii) Does not contain an endorsement stating that the applicant has not met all of the standards of ICAO for that license;
(3) Does not currently hold a U.S. pilot certificate;
(4) Holds a current medical certificate issued under part 67 of this chapter or a current medical certificate issued by the country that issued the person's foreign pilot license; and
(5) Is able to read, speak, write, and understand the English language. If the applicant is unable to meet one of these requirements due to medical reasons, then the Administrator may place such operating limitations on that applicant's pilot certificate as are necessary for the safe operation of the aircraft.
(c) Aircraft ratings issued. Aircraft ratings listed on a person's foreign pilot license, in addition to any issued after testing under the provisions of this part, may be placed on that person's U.S. pilot certificate.
(d) Instrument ratings issued. A person who holds an instrument rating on the foreign pilot license issued by a contracting State to the Convention on International Civil Aviation may be issued an instrument rating on a U.S. private pilot certificate provided:
(1) The person's foreign pilot license authorizes instrument privileges;
(2) Within 24 months preceding the month in which the person applies for the instrument rating, the person passes the appropriate knowledge test; and
(3) The person is able to read, speak, write, and understand the English language. If the applicant is unable to meet one of these requirements due to medical reasons, then the Administrator may place such operating limitations on that applicant's pilot certificate as are necessary for the safe operation of the aircraft.
(e) Operating privileges and limitations. A person who receives a U.S. private pilot certificate that has been issued under the provisions of this section:
(1) May act as a pilot of a civil aircraft of U.S. registry in accordance with the private pilot privileges authorized by this part;
(2) Is limited to the privileges placed on the certificate by the Administrator;
(3) Is subject to the limitations and restrictions on the person's U.S. certificate and foreign pilot license when exercising the privileges of that U.S. pilot certificate in an aircraft of U.S. registry operating within or outside the United States; and
(4) Shall not exercise the privileges of that U.S. private pilot certificate when the person's foreign pilot license has been revoked or suspended.
(f) Limitation on licenses used as the basis for a U.S. certificate. Only one foreign pilot license may be used as a basis for issuing a U.S. private pilot certificate. The foreign pilot license and medical certification used as a basis for issuing a U.S. private pilot certificate under this section must be in the English language or accompanied by an English language transcription that has been signed by an official or representative of the foreign aviation authority that issued the foreign pilot license.
(g) Limitation placed on a U.S. private pilot certificate. A U.S. private pilot certificate issued under this section is valid only when the holder has the foreign pilot license upon which the issuance of the U.S. private pilot certificate was based in the holder's personal possession or readily accessible in the aircraft.
Hope that helps.
