When "Patchy" is used to describe runway conditions in the notams, can you assume the runway to be less than 25 percent contaminated? Example: PTCHY THN PACKED SN AND ICE
I was recently informed this is general knowledge and defined in the AIM however, I cannot find it.
Good question....a quick call to FSS got me the answer. Located in FAA publication 7930.2 (NOTAMS), Chapter 5, 5-1-4 states -
"c. Coverage. Do not express the condition in terms of percentage of coverage. A surface not completely covered should be described as having patches of snow, ice, etc.; e.g., PTCHY y IN SNW (surface). The absence of a described surface indicates the entire landing area"
So basically if there is ANY snow on the runway, but not completely covered, it's patchy...
