uwochris
Flightinfo's sexiest user
- Dec 21, 2001
Hey guys,
I have a question regarding the governor system on constant speed props.
I understand the basic principles of how these things work to maintain a constant RPM by varying the blade angle. It's also my understanding that the governors are geared to the engine, and that the flyweights rotate at the same speed as the props.
I am, however, confused as to what really goes on when one adjusts the RPM control (the blue lever). When you move the control, is the pilot adjusting the tension on the speeder spring, or is somthing else going on? I know that there has to be an equilibrium between the speeder spring force and the oil pressure, so I assume one or the other has to be affected by the prop lever.
Thanks in advance for any comments,
Chris.
Chris.
