The "oversquare stuff" most certainly did not apply to radial engines, most all of which were turbocharged, supercharged, or turbocompound boosted. Most large radial engines are operated with manifold pressures well in excess of RPM values. There is NO correlation between manifold pressure and RPM.
A myth, perpetuated by inexperienced flight instructors who don't know better.
Particularly in a normally aspirated engine, just how are you going to overboost it?? You can never develop more than barometric pressure...if you're operating above sea level, you're always developing less pressure in those cylinders than the engine was designed to handle.
The highest pressure you can develop with the engine running at full throttle is whatever you would develop with the engine shut off, no matter what position of the throttle. Think about that.
keep your prop rpms higher than your manifold pressure setting -- i.e. you don't want to overstress the engine by having a higher manifold setting than your prop setting.
