Cold Wx Altimeter Correction???
A squared, thanks for the info. Do you know of a document that states this?
I had no clue that the altimiter setting was corrected for temp.
I do not think there is any correction for temperature. And the altimeter does not "calculate" anything. It is a simple clockwork mechanism that changes the hands by 1,000 ft for every 1 inch of Hg pressure change. Every time. There is a bi-metallic yoke in the case that does bias the reading but its purpose is to compensate for the local temperature right there in the panel. How much bias....no one seems to know. :) I asked that question at a Terps meeting 40 years ago. I still do not have the answer.
DC
paulsalem said:
I think he and Asquared are right.
http://www.nwstc.noaa.gov/DATAACQ/d.ALGOR/d.PRES/PRESalgoProcess.html#
Check out number three.
They use tempature in the formula.
Aren't you confusing Station Pressure with altimeter setting. In any event the transmitted altimeter setting figure will cause your altimeter to read the field elevation when that is where it is on the airport and nothing is corrected for the non-standard atmosphere above, if it is non-standard. IMHO.
DC
Thanks,
With winter firmly upon us, this is very useful information.
I sent an email to the NOAA ASOS people asking the same question.
I'll post once I get a response.
What company makes the ASOS?
Well, actually, yes it does. It measures pressure and computes and displays altitude (actually, an estimate of altitude) through it’s mechanism. An altimeter is in fact an analog mechanical computer, although that may be a little abstract for some, but it is true nonetheless.
You are correct that it is a relatively simple clockwork mechanism, you are absolutely incorrect that it changes the hands 1000 ft for every 1 in. Hg pressure change. Pull out a chart of the IACO standard atmosphere. At sea level, 1000 ft is 1.06 in Hg. The difference between 19,000 ft and 20,000 ft. is 0.59 in. Hg. That is a *LONG* way from 1 inch each and every thousand feet. Even in the idealized standard atmosphere, pressure is a non-linear function of altitude
I should probably clarify what I meant by altimeter settings being corrected for temperature. True, they don’t take a pressure reading then apply a factor to it based on temp, however an altimeter setting, by it’s nature takes into account the effects of non-standard temp. Atmospheric pressure ant any point will be affected by the pressure patterns ant temperature, and possibly other factors. So if you compute an altimeter setting for a location based on the measured atmospheric pressure at that location, the altimeter setting will account for any factor which affects the pressure, including the temperature.
What they are doing in step three is adjusting for the altitude difference between the pressure sensor and surface of the field, and that altitude correction includes a term for temp.
I hate to argue with you, but using the anticeptic language that you do, you are correct in a way but: a mechanical barometric altimeter does not account for any non-linear pressure or temperature lapse rate as far as I know.
The electric altimeters that get a signal from the air data computers are corrected for some errors but if you compare them with the mechanical standby altimeter while in flight at say M.80 at FL350 you see only a couple of hundred feet difference between them. One's actual altitude may not be anywhere near 35,000ft even if the local altimeter on the ground below is 29.92". One would have to consult the relevant constant pressure chart to see at what height above the standard datum plane the equivelant pressure level is. Who does that anymore?
But our discussion here I thought was for appoach error.
The FAA does not expect us to make the cold temperature correction. Should we? I don't know. If you look at high, cold airport IAP charts for say Jackson Hole WY, and look out at the procedure turn area where the Required Obstruction Clearance is 1,000 ft I think you will find that the actual clearance is more like 2,000 ft. There is nothing in TERPS that I can find that would cause the procedure specialist who designed the procedure to build in that significant extra margin but they seem to be doing it.
It is time that the Feds clarify these things IMHO.
Best, DC
This is a great thread. You guys who are flying with FMSes need to be aware that some of them can correct for low temperatures. About the only time I've ever used the feature was up in Canada and Alaska. If you've got questions, get out your manuals and do a little research.
'Sled
