Citationshares
Re: Supersonic in the X ...
Snakum said:
I caught a Discovery Channel special on business jets in which they rode along on a test flight in a new CX. The test pilot, when talking about how they explore the envelope for each one off the line, said "these jets will go supersonic" ... they've obviously done so in testing. But I'll bet others have as well. I would imagine you'd wanna bump the speed envelope pretty good when certifying a new design to ensure it isn't gonna instantly fall apart or become uncontrolable and unrecoverable when someone inadvertantly hits mach 1.
No one has a supersonic test point for an airplane designed for sub-sonic flight; the wing and tail and even the fuselage designs differ dramatically for flight in compressible versus non-compressible conditions.
Determing VD and MMO is determined during developmental test and is governed by FAR 25.253, FAR 25.335 and FAR 25.1505.
For most designs, flutter, a destructive-non reversible mode, determines VD and susequently MMO. In the GV, limiting speed was when rudder CLBeta went positive at about .96 mach. This is a very benign aerodynamic effect. If you are conservative you back off M.07 from this speed to determine MMO, if you're not you back off M.05. Gulfstream is very conservative hence the .885 MMO.
Every airplane is born without a Certificate of Airworthiness. Factory Production Test Pilots are authorized by the FAA to fly what is normally around a 40 page FAA approved test card to prove that each airplane meets the requirement of FAR 25 before a C of A is issued. The FAA initially flys each fifth flight with a factory pilot. As the design becomes more mature the FAA backs off to every 10th flight and the test card requirements become less stringent. For the first GV's the test card required that each jet be flown at M .955 to insure that no adverse control characteristics were present should the airplane ever get away from the pilot. The current requirement is to take each GV to M.92. Each G-IV goes to .90 to get a Cof A.
Cheers
GV
HEHEE... What a heated thread....
Thats ok, I'll race either of you guys (C-X or G-V) for a years salary!
But first we each shut down 2 engines.... DOH! ;)
You guys are arguing all the wrong things. Only one thing really matters here.
The Citation X is a sexier looking airplane. Hands down, the thing is just gorgeous. It's like if I have a Cadillac and a Ferrari in the garage, and want to impress the ladies while out on the town - I'll roll in the Ferrari. Yeah, the Caddy is bigger and maybe better appointed, but the Ferrari is going to be the one to turn the heads.
Bottom line: if I'm cruising the country for chicks - I'll be flying the Cessna. :D
I think I started this whole thing. All I wanted to know was how the X flies:) They are both beautiful Aircraft. Both do a wonderful job....and speaking of jobs......I am in need of one....any one.
As my resume sez......I will cheerfully relocate......I would gladly fly the X or the V or IV or III or II hell anyone know of a I job? Thats either brand:)
gunfyter said:
I am in the slowtation V Ultra but it seems to me I often hear on ATC -- the Falcon 2000 slowing down for Gulfstreams.
Now that does not compute according to advertised performance of these aircraft.
We often times have to slow for Gulfstreams and other jets... I believe the Gulfstream IV and Gulfstream V have a Vmo or 340 kias, our Falcon 900EX's and 50EX's have Vmo's of 370 kts...
And before GVFlyer gets his undies in a bunch, I've had to slow for a Citation X also, their Vmo is 350 kias I believe....
I'm disappointed neither of you guys have accepted my generous offer!
Very funeee, Falcon...
Hmmmm, Wait....Maybe if we start 250 miles from destination and I'm at 51,000 feet.......
BigD,
Obviously you're the one going home with the fat acne-laced chicks at the end of the night, because the X is downright ugly, both inside and out, compared with any of the Gulfstreams.
There isn't a better looking plane on earth.
bigD said:
I'm curious - how well does the Falcon fly on just one engine?
Well in the sim with the Falcon 900EX, we would do 2 engine out go arounds in Denver on a 30°C day at moderate weights.... It will climb to about 12,000 ft or so... on drift down it will come down to around 15,000 after something around 90 minutes or so (would need to look at the charts... The 900EX has a lot better performance than the 900/900B or 900C
Them's fightin' words zman!:D
You need to put your glasses on and look again. I wonder - do you drive a Pontiac Aztek too? ;)
QUOTe---------------------------------------------------
You're right, but the GV is less expensive than the C-X by the pound.
Good remarks to all my comments GVFlyer,
But where is your math on the quote above?
I have to use more sick days to keep up with this board.
.92 out
Aw, shucks...thanks.
Sure, here goes....
GV purchase price - $43,200,000 divided by weight - 90,500 lbs = equals $477.35 price per pound of Premium Grade A Choice airplane.
C-X purchase price - $19,000,000 divided by weight - 35,700 lbs = equals
$531.22 price per pound of aircraft.
Hence, a net savings of a whopping $53.87 a pound when you purchase a GV. Check your local newspaper for discount coupons.
.92 out
LOL!
GV
capt_zman said:
BigD,
Right on, my man! If the GV looked any better children under 17 would have to be accompanied by a parent or guardian to even look at it!
GV
Here's an idea...
Park a G-V next to a Global, a Falcon 900EX, and a Citation X and see which jet attracts the most attention. I know the result and so does GVFlyer, because we park our jets next to the others all the time and the crews always want to look at ours. It's never the other way around.
FL510GV said:
Here's an idea...
That's because as pilots we tend to be attracted to the biggest, most expensive piece of equipment on the ramp. If a BBJ were to be parked next to your plane, I'd bet we'd all be over there. But certainly not because it's a better looking jet!
But hey, if someone asked my low-time a*s to fly your homely Gulfstream, they probably wouldn't have to do much arm twisting. ;)
FL510GV said:
Here's an idea...
I must disagree with you on that statement ... hell, even your own Airforce peers flooded me on two different occasions. I had so many IP's and students crowded in my cabin, asking questions, that we didn't have room to move. Last few times I've been around any GIVs or GVs, the onlookers and pilots were walking over to our jet. Bigger doesn't mean better. I can assure you of that from first hand experience partner.
750Driver - if you're ever at AUS, I might very well be one of those guys crowding your cabin! Never been in one, and any time one is on the ramp it's all closed up. One of these days I'm gonna get lucky! :D
BigD:
I've been to AUS' Signature many times, with the X shown on the left. All you needed to do was ask my friend ...
what the hell?
gee-susss....
Are you gonna talk about Citation shares? or the newest Car and Driver comparison tests of the Cx and Gv? put it on the general board or something and let everyone discuss Shares eh?
try this one out.
4000 pounds of paletized freight, 500 miles. my E110 would kick both planes asses! <thats if an airplane could have an ass..> cause you couldnt fit it through the door ! ...boo hoo.
just cut it out and let everyone talk shop about shares,...theres already TWO PAGES of this Cx Gv garbage going on.
...man!...
More road tests
I thought it was pretty interesting learning about airplanes at the other end of the spectrum from what I fly.
What was your comment about the Citationshares program, Robbie?
comment?
its this,
theyre hiring but specific people. bee good and make sure you want to be there for a long time. they dont want an aspiring 747 airliner captn. there to leave shortly after. they pay good and very fair people. thats what i know. ive got an in but im not good with customer service. ill shoot through a level 4 and forget im hauling people and not freight. also ill wonder why they cant take it as well as i can....id rather thank them for flying withus instead of asking what hteir catering in the morning should be and then picking up after them. theres airlines to do that for me ;>
Shoot through a level 4? In a Bandeirante?? And it held together??? Dude, you are living on borrowed time. I wouldn't worry about customer service at CitationShares or paying for your hotel while in training at ACA. I reckon you've gone about as far as you're gonna go in this business.
Jeepers...level 4? Thanks, but no thanks. I took what I thought was a wide berth around one (I eyeballed 20 miles) last year in an A36 and still managed to get pelted by some small pebble sized hail (while in VMC). Thank God it wasn't big enough to hurt the plane. I either need to aim for 25 miles, or get better at judging distances!
TSTMS
The old rule of avoiding thunderstorms by 5nm above the freezing level; 10nm below and 25nm above 20,000 feet works for me. Heck, I don't even like to get the airplane wet!
