banned username 2
Banned User
- Nov 25, 2001
That is BS...urflyingme?! said:I have heard that there is a supposed "mach kit" that allows the citation X to exceed mach 1.
Is it "bull"?
Is it "bull"?
I know many Falcon 10's were pushed past 1.0M in a dive by "Cowboys"...Vladimir Lenin said:with the level of anonymity that this board provides... I would hope that at least someone who flies an X on a regular basis would come out and enlighten us a bit on this subject
I know I pushed a 172 past the red a few times, without apparent flutter issues![]()
Yes a X did lose a eng cowl in flight. One of the many things Cessna said "It can't happen" but did. The latches were all intact, and found secured and locked by the way......sans cowling.Mudworm said:Heard once while in FSI Witchita that a X came into the srvice center there missing an engine cowl or two.
1000000000% incorrect.Mudworm said:Rumor had it that the crew was doing some high speed test flying on the decent to ICT!
Part 25 requires that any new civil aircraft be test flown to "a speed at which characteristics detrimental to safe flight begin to occur", then the Mmo is designated .08 Mach below that speed, or .08 Mach below Mach 1.0, whichever is less.xrated said:As it was explanined to us, during flight test, Cessna had to prove the airplane would hold up .7 above Mmo. Hence a .92 Mmo for the X. Any higher, aka Mach 1, you are dealing with a whole nother beast.
14 CFR 25.335 (b)(2) The minimum speed margin must be enough to provide for atmospheric variations (such as horizontal gusts, and penetration of jet streams and cold fronts) and for instrument errors and airframe production variations. These factors may be considered on a probability basis. The margin at altitude where MC is limited by compressibility effects must not less than 0.07M unless a lower margin is determined using a rational analysis that includes the effects of any automatic systems. In any case, the margin may not be reduced to less than 0.05M.FracCapt said:Part 25 requires that any new civil aircraft be test flown to "a speed at which characteristics detrimental to safe flight begin to occur", then the Mmo is designated .08 Mach below that speed, or .08 Mach below Mach 1.0, whichever is less.
DOH! There I go again...trying to remember things...when I should really look it up to be positive before I spout off.Falcon Capt said:14 CFR 25.335 (b)(2) The minimum speed margin must be enough to provide for atmospheric variations (such as horizontal gusts, and penetration of jet streams and cold fronts) and for instrument errors and airframe production variations. These factors may be considered on a probability basis. The margin at altitude where MC is limited by compressibility effects must not less than 0.07M unless a lower margin is determined using a rational analysis that includes the effects of any automatic systems. In any case, the margin may not be reduced to less than 0.05M.
M0.92 + M0.07 = M0.99 uncorrected, if they utilize an "automatic system" (guessing Mach Trim) the margin may be reduced to M0.05.
M0.92 + M0.05 = M0.97
LOL!!! No Prob... I had to look it up myself!FracCapt said:DOH! There I go again...trying to remember things...when I should really look it up to be positive before I spout off.![]()
