Citation cross-certification
This site (a training company) says:
  • Cessna Citation Jet CJ, Cessna Citation Jet CJ1, Cessna Ciation Jet CJ1+ (CE-525)
  • Cessna Citation CJ2, Cessna Ciation Jet CJ2+ (CE-525A)
  • Cessna Citation Jet CJ3 (CE-525B)
  • Cessna Citation Jet CJ4 (CE-525C)
  • Cessna Citation M2
That is true, per the FAA, but insurance companies are going to have some more restrictions.
Definitely not the Citation 3.
Seems people have confusion between the CJ3 (CE-525B) and Citation 3 (CE-650). Different animals.
Also add the CJ3+ (CE-525B) to this list.
As the other poster said, yes, do not confuse the CJ3 with a Citation III. Completely different animal and type. However, do watch the FBO's, they occasionally confuse the CJ3 with a Citation III and want higher ramp fees or a larger fuel upload.
What is a CE-500 and a CE-550?
Hi Hugh,
This is the exact verbiage on your certificate if you are not single pilot rated:
THIS CERTIFICATE IS SUBJECT TO PILOT-IN-COMMAND LIMITATION(S) FOR CE-525.
CE-525 SECOND IN COMMAND REQUIRED.
The CE-500 is original Citation. CE-550 is the V. Generally speaking, in true Cessna Mr. Potatohead fashion, as the numbers get bigger the airplane gets longer.
C-500 covers the original Citation, the II, S-II, Bravo (II with trailing link gear and P&W engines), the V, the Ultra (560) and Encore (560 but with trailing link gear and P&W engines).
It doesn't cover the 560 XL. It sort of did allowing a short course if you had experience in the Ultra, but with the new avionics it doesn't now.
There is a big difference between the typical Original Citation and an Encore, but the type covers them. Get good training.
The 500 is the Citation 1
550 is the Citation II and Bravo
560 is the Citation V Encore and Ultra
All of these fall under the 500 type rating with differences courses.
thanks always wondered
