msuspartans24
- Aug 12, 2004
msuspartans24 said:Got a friend who flies the Cheyenne 400 and swears by his life that it is an all around better airplane than the king air. Just curious if anyone with some time in both would agree.
mzaharis said:An interesting review of the Piper 400LS - The website was shut down, so here's the cached version from google.com:
Page 1
http://64.233.161.104/search?q=cache:foaIj38skjwJ:www.fliteguide.co.za/Imperial_Aviation/Full_aircraft_reports/FR_piper_cheyenne_pg1.htm+%22cheyenne+400LS%22+%22imperial+bank%22&hl=en
Page 2
http://64.233.161.104/search?q=cache:3hjFlvB80D4J:www.fliteguide.co.za/Imperial_Aviation/Full_aircraft_reports/FR_piper_cheyenne_pg2.htm+%22cheyenne+400LS%22+%22imperial+bank%22&hl=en
Excerpts:
The result is astonishing. The 400LS will out climb most small to medium business jets. In terms of hard numbers, it has a maximum true airspeed of 360 knots and will cruise at over 40,000 feet at 340 knots for nearly seven hours. It will accomplish this seating nine people in stretch-out comfort and at less than half the fuel burn of a Citation II. . . .
During the pre-flight walk about it is clear this is a Piper and not a Beechcraft product. PHO's age is beginning to show in the general fit of the panels and particularly on the fibreglass mouldings, which were beginning to craze. The heavily over-engineered solidity of Beech products seems to be lacking, most obviously when looking at the access panels which appear to be loose fitting. . . .
The huge power of this Piper has made this not just a hot rod special of limited utility but an aircraft of immense practical use. It is capable of taking as many people as a Citation I a far greater distance at a similar speed. The owner says that on a Lanseria to Luanda leg, the aircraft can carry more payload than a King Air 200. With 2,000lbs of fuel for four hours there is still capacity for another 2,200 lbs of passengers. Typical fuel burn at a high cruise level is 400lbs (60 US gallons) an hour - half that of a comparable Citation. With total useable fuel of 570 gallons, the aircraft can comfortably make Johannesburg to Mauritius non-stop. . . .
mzaharis said:It will accomplish this seating nine people in stretch-out comfort and at less than half the fuel burn of a Citation II. . . .
