CFII Ride
FlyinTim
Im gettin ready for my II ride...any stories about the oral/flight?... I already have my initial so im sure it wont be as bad...
Easiest checkride I've taken. Taught NDB approaches and holds on the ground, and in the air, demonstrated/taught one NDB approach, one NDB hold partial panel, and one VOR approach. Done.
Easy.
taught VOSR's and interception,compass turns,pitot/static system,vacuum system, holding speeds, draw out an ILS. done..
Flight. radial intercepts and tracking,ILS,NDB partial panel. fairly simple
My CFII was the first instructor ride I had taken, so for the oral a big part of it consisted of the FOI, endorsements, instructor certificates, etc.
As for actual technical areas, my big lesson I had to teach was on "All Things Magnetic Compass." Outside of that we didn't discuss a whole lot of technical subjects.
Also got a couple Lost Comm scenarios. The type where they dont want to hear the rote answers, they want to see you apply it to an actual situation.
I also had to do a flight plan to another airport 120 miles away. Explained briefly my flight planning procedures then got hammered with quite a few more "scenario" questions based on my plan. Total ground: 2.8
For the flight, I had to file my above flight plan, and we picked up the clearance on the ground, then flew it like you normally would. We flew it for about 5 minutes (just long enough to get on course and out of controlled airspace) then the fun began. He flew, and I taught: GPS Approach, VOR Approach, Autopilot-Coupled ILS Approach, DME Arc, and a the obligatory hold over one of the local VOR's. Then we shot another VOR approach back into our home airport and did a Circle To Land to full stop. Total flight: 1.6.
My biggest reccomendation is to go buy the "ASA Instrument Oral Exam Guide" if you haven't already and know and be comfortable with every question in there. And of course the IFR Regs are a big one, especially since you will be the instructor now and won't have the crutch of someone else who should know to back you up.
Any idea when you might be ready to take the II ride?
Alchemy said:
I didn't even wear a view limiting device.....
Why should you have been? You should've been teaching, not showing your proficiency at instrument flying!
Is it typical for people to do their CFII ride with view limiting devices??
LMAO
I just got this mental image of someone making the examiner put on the hood for an "instrument takeoff".
LMAO
-mini
I wouldn't say it is "typical" but it isn't unusual either to do a portion of the II ride with the view limiting device on. It will vary depending on the DE. The ride is not very difficult, should be nothing "new" to you....
3 5 0
