Flyin Tony
- Mar 5, 2004
I would say Yes.Flyin Tony said:A friend of mine just got his CFII and has not flown in a cloud for over a year. Does the II checkride count as a IPC. (i dont think he will be going into any clouds untill he goes up with a CFII) I havent found anything in the FARs that have any INFO about this.
thanks Tony
You need to look at some of the threads on BFR currency and CFI rides. The most current FAA view, based on an FAA Regional Counsel interpretation and repeated in the Part 61 FAQ, is that a CFI ride does =not= restart BFR currency unless it is accompanied by a FR endorsement, for exactly the reason you said: it involves a "flight instructor certificate" not a "pilot certificate" That's what I was referring to in my earlier post.kclark said:I would say Yes.
Because the CFII is just an instrument rating added on your flight instructor certificate. So your instrument currency would start the date of the check ride. This would also be the date you start your BFR currency.
FAA view is going to change from each section of the country. Each FSDO has their own way of doing things.midlifeflyer said:You need to look at some of the threads on BFR currency and CFI rides. The most current FAA view, based on an FAA Regional Counsel interpretation and repeated in the Part 61 FAQ, is that a CFI ride does =not= restart BFR currency unless it is accompanied by a FR endorsement, for exactly the reason you said: it involves a "flight instructor certificate" not a "pilot certificate" That's what I was referring to in my earlier post.
But the FAA Regional Counsel opinion is.kclark said:FAA view is going to change from each section of the country. Each FSDO has their own way of doing things.
Technically that Part 61 FAQ is not legal interpretation.
Not really cause they're the ones who decide whether or not to file a violation. Even if it later gets thrown out, it's still a major hassle.igneousy2 said:The local FSDO opinion counts almost as little as my opinion.
I believe you're emphasing the wrong term in the FAR. The key term is PILOT PROFICIENCY CHECK. The remainder of the reference merely mentions the different types of pilot proficiency checks that may be credited toward a flight review. A CFI check is not a pilot proficiency check and a flight instructor certificate or rating is not a pilot certificate or rating.kclark said:Still not response from the laywer.
A person who has within the perdio specified in paragraph (c) of this section, passed a pilot proficiency check conducted by an examiner, an approved pilot check airman, or a U.S. Armed Force, for a pilot certifcate, RATING, or operating privilege need not accomplish the flight review required by this section.
Now if you got to 14 CFR FAR Part 1 and look up the definition of rating.
Rating means a statement that, as part of a certificate, sets forth special conditions, privleges, or limitations.
It was about an IPC check, and there was some discussion about BFR as well, if you read the entire thread.transpac said:I believe you're emphasing the wrong term in the FAR. The key term is PILOT PROFICIENCY CHECK. The remainder of the reference merely mentions the different types of pilot proficiency checks that may be credited toward a flight review. A CFI check is not a pilot proficiency check and a flight instructor certificate or rating is not a pilot certificate or rating.
P.S. I thought the issue was an IPC???
There's certainly some truth to that, although it shouldn't be that way. At any rate, the FSDO does not decide what is legal and waht is not. that is decided by the FAA counselkclark said:FAA view is going to change from each section of the country. Each FSDO has their own way of doing things.
THis is true, and it's an important point that shold be kept in mind when reading the FAQ. THere are some things in the FAQ which are just flat out wrong. This *particular* item in the FAQ is a direct verbatim quote of an interpretation from some office of regional counsel (Eastern region, I think), and as such it *IS* an official legal interpretation. Regional counsel is not "the FSDO", they answer to the office of chief counsel.kclark said:Technically that Part 61 FAQ is not legal interpretation. .
Well, actually it *does* specify pilot certificate. Furthermore when it says Pilot certificate, rating or operating privelige, it does mean pilot certificate, pilot rating or pilot operating privelige. Otherwise completing a 121 flight engineer PC (non pilot PC for non-pilot operating privelige) or adding an Airframe rating to your Mechanic's certificate would both count as a BFR.kclark said:Note is does not say 'pilot certificate'. There fore a BFR is not required if you earn your flight instructor certificate, or add a rating to that instructor certificate..
Try it this way:kclark said:A person who has within the period specified in paragraph (c) of this section, passed a pilot proficiency check conducted by an examiner, an approved pilot check airman, or a U.S. Armed Force, for a pilot certificate, RATING, or operating privilege need not accomplish the flight review required by this section.
kclark said:Figured I'd post the reponse from the laywer.
An initial CFI applicant can use the checkride to count for the flight review, but it would be advisable to also have the examiner make the flight review endorsement in the airman's logbook as well, to ensure that they have "credit" for it.
It's the same problem as the wording in John Lynch's FAQ. "Yes, but you also need the endorsement" means the exact same thing as "No" but is just not worded as well.A Squared said:Not to pick nits, but your lawyer's advice is incorrect, or at least worded in a misleading manner
