Both sides are right on this.
1. The airplane doesn't care if it is in still air or moving (as long as its a steady-state wind)
2. Downwind turns ARE dangerous (but only when close to the ground)
Concerning point 1: The inertia type arguments don't pan out. Try doing a 180 in 100kt plus winds and you will see- the airplane doesn't care.
Concerning point 2: Its simply a matter of climb gradient. The RATE of climb will be the same with a headwind or tailwind. The ANGLE of climb relative to the ground will change. (clearly a poor ANGLE of climb is what is hazardous when you need to clear obstacles)
So low-level downwind turns are more dangerous than upwind turns due to the increased groundspeed which causes a decreased climb angle (remember angle of climb is the aircrafts ability to climb over distance relative to the ground) and thus reduced performance in regards to clearing obstacles.
Note: When I say "low-level" I mean low enough that nearby obstacles are a concern. 1000 feet over prairy land doesn't count. 10 feet with a tree line ahead does.
I would speculate that the other phenomina observed by some pilots (eg. incleased RATE of climb when turning upwind) are an illusion based on groundspeed and angle of climb.
The same maybe for those who say you lose airspeed... if you were doing a low level climbing turn to an increasing tailwind component the decreasing climb angle (due to increasing groundspeed) would cause the pilot to compensate and get their climb angle back by raising the nose, thus losing airspeed. The proximity of the ground is providing a reference of climb angle that doesn't exist higher up.
