CFI myths..Special VFR day/night et al
northmountain
Active member
Here's a new one. A fellow instructor told me that they changed the regulation and you need an IFR rating (and aircraft IFR equipped) to fly under Special VFR during the Day (as well as night). Oh really?
I thought I lost my marbles, but checking with other CFIIs and a lawyer, I can see where the confusion is:
91.157 Special VFR weather minimums
b) Special VFR operations may only be conducted--
(1) With an ATC clearance;
(2) Clear of clouds;
(3) Except for helicopters, when flight visibility is at least 1 statute mile; and
(4) Except for helicopters, between sunrise and sunset (or in Alaska, when the sun is 6 degrees or more below the horizon) unless--
(i) The person being granted the ATC clearance meets the applicable requirements for instrument flight under part 61 of this chapter;
SO in English...You need 1 and 2 and 3 and operate in daylight (ok, ok, between sunrise and sunset). Then, if you don't operate between sunrise and sunset, (in other words you now operate at night) then the instrument stuff comes into play.
What irks me is that this gets told to a student, who tells another student who tells...etc....etc....and PRESTO a myth is borne.
CFIs really need to watch what they are teaching! Students often look to us as the final authority.
Any other myths that you guys and gals were told as students that you later found out were total bunk? I know I have plenty.
We aren't talking about flying techniques; we're talking FARs, aerodynamics, systems etc.
How 'bout this one....."when you get into ground effect you are compressing the air below the aircraft" ARRRRGGHGGHH!!!
North, I have never hear that particular reg misunderstood in that way. Clearly, the instrument rating is for the night op, not the day special VFR.
Once you straighten out your friend, you can encourage him to go back over this with his students and show them where this misunderstanding can develop.
Although there are some myths about flight itself that seem to persist (the dreaded "downwind turn" for example), Most of the ones that I've seen seem to be, like this Special VFR one (I have heard it from a ground instructor), seem to be in the regulation area.
The "logging" vs "acting as" PIC ones come to mind immediately. Of course some of the questions when the subject is bantered about get silly, but there are still a substantial number of CFIs out there who think that an ASEL rated pilot simply =cannot= log the training time that he receives for the complex, high performance or tailweel endorsements as PIC.
Midlife...
What's this "downwind turn" misconception....I'm not familiar.
Jedi: Yeah, dihedral: It's there to drive you crazy and give you dutch roll, or lateral-directional oscillation. If I really said that a studen would look at me like this:eek: :eek:
Assuming a strong constant wind, you will lose airspeed when turning from upwind to downwind. So it's very dangerous turn from upwind to downwind at a slow airspeed or too much bank because you could easily stall.
Oh, yeah, that's a good one. Reminds me of the old "you need more power in the left turn than the right turn" BS. Reasoning was that pitot is located on left wing so in left turn it is not going thru the air as fast; hence, registering a lower indicated airspeed. I saw a trig proof of this and it comes out to 1 knot or so. Hardly a reason to add more power. However, I guess one could argue that THEORetically, it is true:rolleyes:
I'm all for truth in advertising and correcting myths, but the downwind turn isn't all myth. In theory, you can initiate a turn upwind or downwind, watching only the aircraft instruments, and will see no change. The aircraft has no idea what's occuring with winds, as it's in a fluid environment. Ground track changes with wind, but airspeed does not. So goes the explaination of reason.
Those who do this explaining haven't ever had to make a hard turn downwind in a critically loaded airplane, and had the opportunity of watching the airspeed bleed to nothing.
I've heard the arguements made over the years, and I've even tried arguing both sides. The science of it says that in theory there's no such animal as the effected downwind turn, that wind has no effect on the downwind turn. Science is supported by inspection of many downwind turn accidents; we see that the pilot made the mistake of visually seeing groundspeed and turn radius increase, applied back pressure and steepened bank to compensate, and lost airspeed and eventually stalled.
Very common. However, there's more to it.
If an airplane had no mass or inertia and simply floated as a speck in the wind, then turning upwind or downwind would make no difference. This isn't the case however. Take an airplane off loaded to the gills in a right crosswind, and make a hard turn to the right. Then do the same thing with a hard turn to the left. You're going to see a difference.
The airplane, if allowed to remain over a single geographical spot and simply rotate about the vertical axis, would see a change in airspeed simply by nature of a heading change. Science tells us that this is of no effect, because the airplane is in a fluid environment, and as it turns, the airplane is also moving with the wind.
An airplane may be turned rapidly such that it will experience an airspeed loss. I understand the theory, but I've seen it happen too many times to doubt it. Doubtless PilotYip will be here to berate that statement along with chides on the history of flight and nonprecision approaches, but he will be wrong. Those who doubt the efficacy of the effected downwind turn simply haven't had the experience themselves. Once exposed to it, it leaves an indellible impression.
I have the stick grip at my hangar residence, from an airplane years ago that stall spun during a downwind turn. It was the last thing that individual touched at the company for whom I flew, in the D model Pawnee before he hit the ground and had the pump brake handle driven through him.
While I realize that such statements will likely raise the ire of many self-opinionated purists, I can't deny what I've seen. I can't necessarily argue it too effectively, either. After all, one should reason that if what I say holds true, then one should be able to perform a steep turn and see a change in airspeed...when clearly this won't be seen.
My first commercial flight employment was ag work, right out of high school; I spent my time doing steep turns at 75' every 30 seconds, usually in wind, in airplanes loaded to the proverbial gills. I'll grant that sometimes climbing out of ground effect while making the turn into or away from an increasing wind gradient also played an effect, but I've seen it in effect toomany times to make a blanket statement that there's no such thing as the downwind turn.
Northmountain, some airplanes do need more power in the turn one way, than the other. Some require rudder input in the turn, others don't. Some have large right hand turning props, others to the left, and it does make a difference...particularly when slow, heavy, and at appropriately high power settings. The difference can be noticable.
avbug said:
I can't deny what I've seen....
Precisely. Most of the explanations I've heard of why the downwind turn myth is true come down to the pilot's perception — seeing a change and acting accordingly.
As you turn the airplane from upwind to downwind, especially in a strong wind, the airplane will begin to move at a significantly different groundspeed. The increase in groundspeed causes a visual illusion of a dive, so the pilot unconsciously pulls up. Bingo! Loss of IAS.
But that's the pilot, not the airplane. I watch my students do this during early turns around a point all the time. Eventually, though, they go round and round from upwind to downwind and to upwind again without a change in airspeed simply by holding a constant pitch. I've always seen turns around a point as the most difficult of the private pilot maneuvers. This is one of a number of reasons.
But for the pilot who reacts to the diving illusion of increased GS, indeed the downwind turn is more dangerous.
The other example you gave is also accurate — the "hard" turn. The sudden full/fast deflection of the controls is momentarily changing the airplane's relationship with the airmass. It's just like when sometimes the airmass suddenly changes it's relationship with the airplane — windshear — with the same result.
In either example, it's still not the change from going upwind to downwind that's causing the problem. Like so many other things, it's the pilot.
Mark,
That might be true for a student pilot. The student pilot or new pilot might be inexperienced enough to not realize that it's him doing such a thing. How about the pilot who makes fifteen thousand such turns a year, into and away from the wind, every thirty seconds or so, and has a chance to experiment?
It's not just the pilot. Perhaps it's just that the real experts on that particular topic aren't great orators...there are those that do, and those that talk, and those that have the most hands-on experience in this area often aren't big talkers.
As I stated before, I'll allow that good science dictates that the downwind turn is a myth, but I can tell you for a fact, that it isn't. And it's not just a matter of a slight airspeed loss.
Rolling into a turn slowly and steadily at altitude in a steady wind is one thing. Rolling hard into the wind in a heavy performance limited airplane is another.
It might be the pilot. However, given that a pilot who repeates the same turn in the same airplane thousands upon thousands of times in all types of winds conditions (calm, left, right, gusting, whatever), one might be given to believe that the pilot has some appreciation for what he or she is doing. If the same airplane is loaded the same way, and turned the same way by the same pilot in varying conditions, and different results are found, perhaps it's the conditions, and not the pilot...dontjathink?
