Cessna 414 Question
Way2Broke
Member
Does anyone know what altitude the C-414 is certified too? I was wondering if it required a high altitude endorsement.
33,000 ft or 35,000 ft, depending on serial number (edit, disregard, I though you wrote 441)
yes
If you are full of fuel and more than one pax you will never get high enough to require an endorsement.
depends on which O2 system, 25k for one, and hahaha, 30k for the big one, it'll only get to 30K if caught in a boomer.
Im sure you were kidding but I think its if the airplane has a service ceil. of about 250
No, he's not kidding at all. With full fuel and a load, the 414 wont make it's service ceiling, period. Now a 421 with a RAM conversion, that's another story!
The 414 is a pressurized airplane and, as such, requires a high-alt. See 61.31(g).
If I recall correctly, the 414 is certificated to 30,000 feet...
You might doublecheck the reg, flyboyike...the endorsement is only required if the airplane is certificated ABOVE 25,000 feet.
...no person may act as pilot in command of a pressurized aircraft (an aircraft that has a service ceiling or maximum operating altitude, whichever is lower, above 25,000 feet MSL)...
Fly safe!
David
I did. The reg states a pressurized aircraft (an aircraft that has a service ceiling or maximum operating altitude, whichever is lower, above 25,000 feet MSL). I've gone as far as to ask my local FSDO whether the use of the parenthesis in this case means an and/or situation or an i. e. situation. For example, I asked, would an aircraft that has a ceiling of greater than 25K but is NOT pressurized need the endorsement? What about one that is pressurized but is certified to only 24K?
The answer from the MSP FSDO was that this was an either/or thing. If it's pressurized you need the endorsement and if it's over 25K you need the endorsement. It need not be both.
And believe it or not, FSDOs around the country are pretty consistant with that interpretation. A pilot of a C-T210M, although not a pressurized aircraft would require a high altitude endorsement.
Interesting...considering that the reg is entitled "(g) Additional training required for operating pressurized aircraft capable of operating at high altitudes." (nothing that talks about unpressurized aircraft), and the training requirements include "(i) Normal cruise flight operations while operating above 25,000 feet MSL"...how do you do that in an airplane that can't legally go there?
Also, the Federal Register Preambles relating to the writing of this reg definitely differentiate between pressurized airplanes certificated above and below 25k.
I might have to ask about this next time I'm at the MSP FSDO.
Fly safe!
David
Agree, the text of the regulation is a little ambiguous, but the title of the regulation makes it absolutely clear what is meant.
In addition to the logical impossibility of a regulatory requirement to for training at cruise altitudes above the maximum operating altitude, the minimum training requirements also include:
"(ii)Proper emergency procedures for simulated rapid decompression without actually depressurizing the aircraft".
Kind of hard to do that in an unpressurized aircraft. If you look at the summary of the Federal Register in which the current regulation was published (FR 62 page 40889,) you will find that there is absolutely no question that it was intended to apply to "pressurized aircraft capable of operating at high altitudes" not to : "pressurized aircraft and high altitude aircraft."
From the Federal Register:
In addition, new paragraph (g) is corrected by including an endorsement requirement for ground training received on the operation of pressurized aircraft at high altitudes. This requirement was included in §61.31(f) before the adoption of the final rule and was inadvertently omitted. New paragraphs (g) and (i) also have been reformatted to more clearly set forth the additional training requirements for operating pressurized aircraft capable of operating at high altitudes and for operating tailwheel airplanes.
Although no further proof should be needed, you can also look at the regulation prior to the 1997 re-write of Part 61.
61.31 (f) High Altitude Airplanes
(1) Except as provided in paragraph (f)(2) of this section, no person may act as pilot in command of a pressurized airplane that has a service ceiling or maximum operating altitude, whichever is lower, above 25,000 feet MSL unless that person has completed......."
Again, absolutely no question that the regulation was intended to apply to "pressurized aircraft capable of operating at high altitudes" not to : "pressurized aircraft and high altitude aircraft."
I’ve said this before, but it bears repeating that the FSDO has no authority to interpret regulations. That is the domain of FAA Legal Counsel, Unless the folks at the FSDO give you an interpretation from FAA legal counsel, whatever they tell you has no official standing, thus, is meaningless.
Agreed...butI wasn't gonna ask 'em for an interpretation ;)
Fly safe!
David
Bump, I'm still confused. This plane has the RAM conversion and has a O2 system that allows for a service ceiling of 30k, however that system is not in operation for our ops, limiting us to 25k. Maybe that will help get a clear answer.
Yea, they are very Caravanesque. However, if you are transitioning up from Aztecs and Seneca aircraft, they definitely are a Lincoln or Cadilac of piston twins.
You're correct, I found that you fuel to the screens for any trip where you're carrying more than just 2 or 3 pax and briefcases.
I liked the 414, but it handles ice about the same way a Caravan does and it doesn't like circling approaches like a 310. You can cut some pretty good circles in 310 with vortice generators.
