172 v. 152
I learned to fly in a 172. I got my instrument and commercial in a 172 (I got an Arrow to demonstrate the high-performance/complex stuff). Then, I trained a number of students in 172s. I don't think I have even 50 hours in 152s, but I've flown them enough to evaluate them as a training airplane.
Both aircraft will do the job. Both aircraft have trained thousands of pilots. Both are used at the name-brand schools and the lesser-knowns. Both are very basic aircraft. I'd go with a 172 because you do have more power, which is an advantage in the summer. You can practice the full range of commercial maneuvers in a 172. I remember I tried lazy 8s and chandelles in a 152, without success. Also, a 172 is more comfortable. If you can find an IFR-equipped 172, that's fine, because you can stay in that same airplane all the way through your Instrument. The others are correct about the (non)spin characteristics of a 172 v. a 152. But if you load a 172 right and the one in question is certificated in the Utility category, you can get it to spin. We had an instructor at Riddle who took our CFI students up for spin training. He could get a 172 wound up really tight.
You''ll be very happy if you can get in a Pen-Yan-modified 180 hp 172. The others are fine, but still underpowered. The 180-hp airplane is a 172 the way it was meant to be.
Good luck with your choice.
PS-I highly recommend that you do not change airplane types during your Private training. In other words, if you choose 152 stay with 152. You don't want to contend with different control characteristics while you're trying to learn how to fly. You want everything to stay as consisten as possible. After you get your Private, you can check out in different types.
