atpcliff
- Nov 26, 2001
Can you descend below DH or MDA??
I was reading the requirements for descending lower than the DH and MDA, am I correct to assume you must have:
1) Stabilized approach
I don't think this is a reg at all, but company policy about when you have to be stabilized or not.
2) Runway enviornment in sight
No. On an ILS you can have the approach lights in site at 200' AGL and continue. At 100' you need to have the runway lights/environment in site to continue.
3) Visibility greater than published for the approach
No. You have to have this visibility prior to the FAF, or whenever the final segment of the approach starts. If the reported vis goes down after this, you can continue the approach. You do have to have the "Flight Visibility" at DH/MDA, but not the "Published Visibility".
Also, you can leave MDA (and this applies to the DH also) to land when you have the runway environment in site, but you may later lose site, as in going into a thick cloud, and you may then have to go around at that time. In this case, in a C-172, your gear MAY hit the runway during the go around.
Correct me if I am wrong........
cliff
ABQ
