Several months ago I had an exhaust valve break on my C-152. Had it repaired, etc. While the cylinder was off the mechanic took a look inside and told me the camshaft was starting to show signs of spalling. I asked him if it was dangerous or going to ruin anything and he said no, and nothing needed to be done until the engine was not making proper RPM's. Opinions needed on that statement.
2nd question is... What is the best/most economical way to get it repaired? The engine has approx 1200 hours TT and all of the cylinder compressions are good. My knowledge of this is that the case has to be split and everything taken apart. Someone mentioned a field repair or would I be better taking it to an engine shop? I don't want to pay for an overhaul at guessing 10K versus 3k for the other work.
Thanks,
Mark
Thanks,
Mark
