LegacyDriver
Moving Target
- Mar 7, 2004
Here's a question that has been gnawing at me for awhile...
How do you start the engines on an F/A-18? Is it a push button, toggle, or a spring-loaded rotary selector button that you have to pull out (a la, "STOP / RUN / START" ?
Also, how do you shut the engine down on a Hornet? Is it another press of the button and if so is there an idle stop safety switch in the thrust lever to keep you from accidentally hitting the button and shutting down an engine by mistake?
