Ex737Driver
Contract 2020????
- Aug 14, 2004
Part 2
COLA Q&A
Q1. Who is eligible for a COLA?
A1. Any pilot can apply for a COLA. Pilots actually furloughed, however, cannot be awarded a COLA. Pilots who are projected to be a double bid pilot due to leave of absence may be considered for a COLA on a case-by-case basis.
Q2. How many COLAs will be awarded?
A2. COLAs will be awarded to the extent they prevent furloughs.
Q3. When do I submit my request for a COLA?
A3. You can submit your request for COLA anytime from June 26, 2008 up to and including Aug. 6, 2008. COLAs will be awarded by Aug. 14, 2008.
Q4. What if I change my mind? Can I withdraw/revoke my request for a COLA?
A4. Once awarded, a COLA cannot be withdrawn.
Q5. What happens to my benefits during a COLA?
A5. All benefits for COLAs are as provided for in the current CBA - Section 13, Part 3, and for Personal Leaves in Section 13, Part 1.
Q6. I received a furlough notification letter from the Company. Can I still apply for a COLA?
A6. Yes. If you end up being above the furlough line, you will be awarded a COLA.
Q7. When will the COLA be effective, and for what duration?
A7. Continental will determine the start date for each participant, but in no case will they provide less than 30 days’ notice. If a pilot wishes to start on another date, the Company will consider that request based on seniority and staffing requirements. COLA extensions will only be offered as long as they mitigate furloughs.
Q8. Can I extend my COLA past 18 months?
A8. All COLAs will be for a minimum of 18 months, with the guaranteed right to extend, either through a COLA extension or a PLA until April 30, 2012. Pilots wishing to extend their COLA must notify the Company prior to each System Bid, and that extension will be granted to each pilot whose COLA either prevents the furlough or allows the recall of another pilot, on a one-for-one basis. In the event that the extension of a pilot’s COLA would not provide that relief, the pilot may apply and will be granted a PLA, to end no later than April 30, 2012.
Q9. What is the difference between a COLA and a PLA?
A9. The main difference is pilots on COLA receive accrual for longevity and active pilot rates for benefits, while pilots on PLA do not.
Furlough Mitigation LOA Q&A
COLA Q&A
