CAL Interview
35) -- What are our bases? Where would you most and least like to be based?
36) -- TMAAT a crewmember asked you to do something that would violate SOP or FARs.
37) -- Who do you recognize as your "internal" customers?
38) -- TMAAT that you did NOT provide the best customer service to your "internal" customers. (I understood INTERNAL customers to mean fellow employees)
39) -- TMAAT that you had to give fast, direct, and time critical orders to your crew. What are the two times you can go below minimums on a CAT 1 ILS approach.
40) -- spit out your holding entry in this manner after you turn inbound: "Ok, it will be a "teardrop entry" (or as applicable), at the fix I will start my time, make an initial left turn to a heading of 150, go outbound for one minute, then turn right to intercept the 360 course to the station to establish myself in the hold."
41) -- TMAAT Sexual Harassment at work
42) -- TMAAT as an instructor you had to intervene and how did you handle it?
43) -- You caught a flight attendant taking alcohol from the first class cabin, what would you do?
44) -- The gate agent needs an on time departure, do you help her by releasing the brakes to start the clock?
45) -- What does working together mean?
46) -- When would you declare minimum fuel and what does it mean?
47) -- What is the minimum fuel required for takeoff?
48) -- What is the difference between a high speed and low speed buffet?
49) Tell us about a time you went out of your way (above and beyond) to help a customer.
50) -- What would you do if you had a Captain that you felt was not taking your inputs or you thought was not listening to you?
51) -- How would you feel about being based in Guam for 18 months?
52) -- SIM PROFILE: . Here is the profile: PF: Pilot Flying (you) PM: Pilot Monitoring Advance power and call: "Set Power" (1.9 EPR) PM: "Power set" One hand on the yoke and the other on the thrust levers until V1. PM: "V1, rotate" Pitch to 20 degrees nose up and climb out at 160kts PM: "Positive rate" PF: "Gear up" At 1000' and 160kts lower the nose to 10 degrees and accelerate. PF: "Flaps up, climb power" Accelerate to 250kts, above 190kts PF: "Slats up, after takeoff" FLY THE FLIGHT DIRECTOR!!!!!!!!!!! And 1.25-1.35 EPR for all phases of flight!!!!!! You will climb up to 4000'. You will then do some turns and cleared to the HUMBLE VOR. The RMI is always pointing to it. Call for the heading that needle is pointing to plus about 5 degrees. This will get you going perfectly. I was 10 miles from the VOR on a 065 course to. PF: "In range checks" At this point I started slowing to 200, command that speed, and dumped the slats below 240kts. I was given "hold NE on the 235 degree radial, left turns, EFC 1745." The PM will read it back to you as many times as you would like. I was right on the line for a parallel or teardrop. The teardrop gave me less of a turn at the fix so that is what I went with. Tell them the heading after the fix, the time outbound, and which way you'll turn after the minute. I actually entered the hold and my mind started wondering about my hold, but I apparently I got it right. I was then given a downwind heading for the ILS 26L at KIAH (no brief necessary). Once this happens start slowing to 160kts. PF: "Approach checks" PF: "Flaps 15, speed" The PM will automatically select the appropriate speed for the configuration. It may be earlier than usual for you to start slowing but remember to give yourself as much time as possible. When the Glide Slope comes alive: PF: "Gear down, landing checks" One DOT below: PF: "Flaps 28, speed" Glide Slope intercept: PF: "Flaps 40, target speed" Fly the flight director all the way down to the ground. It'll be real "wobbly" but try an be as close to centerline as possible. At 20' power should be idle and pitch up 2-3 degrees. You're done!!!!!!
Hope this helps y'all out.
To my anonymous PM'er thanks again. Hope you're not pissed. We owe you a beer!:beer:
