Burning off fuel
Burn in's on the Citation 500's and II's require 3 accelerations and stops from a specific speed based on the part number of the pads. I usually do all three accel and stops on one pass down the runway. Takes about 3 minutes to do it all.
I seem to recall in our C-II we had to accomplish three stops from 35kts.
u got a rejection letter too i see......
it's not saying something negative, it making a obvious attack with no infomation.
So everyone that doesn't think NJ is the place to be got a rejection letter?? It never appealed to me and I never applied. It's for some, but not for everyone.
No matter what the reason, blowing your mains on high-speed taxis should never happen, if you're careful of course.
gents i did this on another thread, everybody take a breath, this is FI, not worth raising your blood pressure, and by the way,Merry Christmas.
I could not agree more with you. The biggest problem I see is that there are some here that feel any question raised regarding NJA is an attack on NJA. You would think that with their large numbers and the amount of flying that they do on a day in and day out basis, that this type of information could be used to educate people. Instead, if you ask why something happens, you are attacking them.
Instead of thinking everyone is "been rejected" by NJA, take it as an opportunity to educate those who don't understand what may have happened to cause such a situation. I like several on here have never heard of a brake burn before, so it is interesting to hear what the educated have to say about it.
As far as the crew meals comment, I am sure this individual is referring to the sheer number of NJA pilots you come across in FBO's across the country on a daily basis enjoying their meals. Was it a shot at NJA, absolutely, but who cares, you guys have the best crew meals of any of the fractionals. That is probably sheer jealousy.
Now it is time for my ham and turkey sandwich.
do we know if it was pilots or MX?
I would be surprised if pilots would be that stupid.
If you need to burn gas you could just set the parking brake in the run up area.
or are we just doing the Flight info dumb*ss speculation scenario?
Does marco island have mx that has the ability or facility to change brakes??... havent been there for years and back then there was no mx facility there.
Does the brake burn aviod burning that coating on the brakes on a landing? I landed a lear with brand new brakes and tires, didn't touch the brakes, and when I turned to park with the tail in the wind I noticed a bunch of smoke blowing past the cockpit. The brakes had smoke pouring out of them. They weren't that hot either. Mx told me it was probably the cleaner they used.
What does burning in the brakes actually do? I've done it in King Airs before, but I forget the reason.
What's the difference betewwn Jeffery Dahmer and a NetJets pilot?
Even Dahmer didn't eat every leg!!!
Properly done, and only on certain brake assemblies, a brake burn in procedure rapidly heats the brake pads or stack to prevent glazing of the abradable material (either pads or rotors in a stack). This was common on small aircraft. Many manufacturers have eliminated the requirement altogether (ABS on some Citations) as there is no noticeable benefit with the new materials being used. A firm application of new brakes on the first landing (preferably to a complete stop) is usually sufficient to "burn in" the stack.
Doesn't sound like they were trying to burn off fuel to me...
I have no idea why you would do 5 high speed taxi's either. MX checks or something? Doesn't make any sense.
What is a brake burn o2bflyn? Never heard of it.
Profrac pretty much explained it they I understand it. I have also heard that newer "style" brake pads that incorporate carbon fiber material do not require burn in time either.
It basically helps the pad and the rotor work better together. More effective braking I guess.
I would just call it "seating the pads". Had to do it on 172's and such to "burn" off the paint on new rotors. Never heard of it on any jets though. It makes sense in the smaller Cessna jets I guess. Thanks for the response though.
From what I understand the plane was down for MX. They were working on the brake lines do to a leak, I'm not sure if they replaced the brakes or not or were just working the brake lines looking for leaks.
Are we done now?
(NJA procedures for fuel burn off requries the plane to be stationary and chocked.)
The only time I've ever done a brake burn in the X is when the FO called "80 knots" and I suddenly realized I left my crew food at the FBO :). Happy Holidays everyone.
You joke, but I know of someone who aborted because he forgot his favorite coffee mug on the FBO counter. He was fired the next day after the passengers complained.
Brake Burns
Newly installed steel brakes require a burn in to remove a coating and fit the pad and disk, so I hear. Mx has a checklist for the flightcrew and it dictates how many high speed taxi/brake applications are required.
We used to do one run - accelerate to 80 KIAS, hammer the brakes ro a stop, taxi back to the ramp and have Mx sign it off.
