building multi time
Yea, I spent several years owning a turbo charged 300 series cessna with two partners that were crooks. I learned a lot and garnered 270 hours of some really good multi time, leading me to my first 135 job.
I wont advise this path for the faint hearted and I wouldn't partner with anyone you want to keep as friends after the partnership is done. You'll find it a true saying..."Everybody is your brother, till the rent comes due".
Well multi time is one of the harder things to get when you are starting out. I found the best way to build the multi was to go out and get my MEI as the school i was instructing for had a twin. The only regret I had was not getting the MEI sooner, i thought i would be able to get multi without having one. Once I had my MEI I was able to build a resonable amount of multi time in a rather short amount of time, I was able to instruct for multi ratings, MEI's and aircaft checkouts. Good Luck
R. Seat King-Air time (?)
This is from a post long ago. Be careful of what you log. If you log PIC and don't have school or training it looks silly in your book. If you log SIC in a single pilot airplane it's not legal time.
Legal Interpretation # 92-14
March 26, 1992
Mr. xxx G. xxx
Dear Mr. xxxxx:
Thank you for your letter of April 3, 1991, in which you ask questions about logging pilot-in-command (PIC) and second-in-command (SIC) time when operating under Part 135 of the Federal Aviation Regulations (FAR). We apologize that staff shortages, regulatory matters, and interpretation requests received prior to yours prevented us from answering your questions sooner.
Your letter presents the following scenario: a Part 135 certificate holder conducts operations in multiengine airplanes under instrument flight rules (IFR). The operator has approval to conduct operations without an SIC using an approved autopilot under the provisions of FAR 135.105. The operator has assigned a fully qualified pilot, who has had a Part 135 competency check, to act as SIC in an aircraft that does not require two pilots under its type certification. Although FAR 135.101 requires an SIC for Part 135 operations in IFR conditions, the autopilot
approval is an exception to that requirement. You correctly state that while the SIC is flying the airplane, he can log PIC time in accordance with FAR 61.51(c)(2)(i) because he is appropriately rated and current, and is the sole manipulator of the controls. Additionally, he has passed the competency checks required for Part 135 operations, at least as SIC.
You then ask two questions. The first asks whether the pilot designated as PIC by the employer, as required by FAR 135.109, can log PIC time while the SIC is actually flying the airplane. The answer is yes.
FAR 1.1 defines pilot in command:
(1) Pilot in command means the pilot responsible for the operation and safety of an aircraft during flight time.
FAR 91.3 describes the pilot in command:
(a) The pilot in command of an aircraft is directly responsible for, and is the final authority as to, the operation of that aircraft.
There is a difference between serving as PIC and logging PIC time. Part 61 deals with logging flight time, and it is important to note that section 61.51, Pilot logbooks, only regulates the recording of:
(a) The aeronautical training and experience used to meet the requirements for a certificate or rating, or the recent flight experience requirements of this part.
FAR 61.51(c) addresses logging of pilot time:
(2) Pilot-in-command flight time. (i) A recreational, private, or commercial pilot may log pilot-in-command time only that flight time during which that pilot is the sole manipulator of the controls of an aircraft for which the pilot is rated, or when the pilot is the sole occupant of the aircraft, or, except for a recreational pilot, when acting as pilot-in-command of an aircraft on which more than one pilot is required under the type certification of the aircraft or the regulations under which the flight is conducted.
(ii) An airline transport pilot may log as pilot in command time all of the flight time during which he acts as pilot in command.
(iii) (omitted).
(3) Second-in-command flight time. A pilot may log as second in command time all flight time during which he acts as second in command of an aircraft on which more than one pilot is required under the type certification of the aircraft, or the regulations under which the flight is conducted.
As you can see, there are two ways to log pilot-in-command flight time that are pertinent to your question. The first is as the pilot responsible for the safety and operation of an aircraft during flight time. If a pilot is designated as PIC for a flight by the certificate holder, as required by FAR 135.109, that person is pilot in command for the entire flight, no matter who is actually manipulating the controls of the aircraft, because that pilot is responsible for the safety and operation of the aircraft.
The second way to log PIC flight time that is pertinent to your question is to be the sole manipulator of the controls of an aircraft for which the pilot is rated, as you mention in your letter. Thus, a multiengine airplane flown under Part 135 by two pilots can have both pilots logging time as pilot in command when the appropriately rated second in command is manipulating the controls. We stress, however, that here we are discussing logging of flight time for purposes of FAR 61.51, where you are keeping a record to show recent flight experience or to show that you meet the requirements for a higher rating. Your question does not say if the second pilot in your example is fully qualified as a PIC, or only as an SIC. This is important, because even though an SIC can log PIC time, that pilot has not qualified to serve as a PIC under Part 135.
An example of this difference is FAR 135.225(d), which raises IFR landing minimums for pilots in command of turbine powered airplanes flown under Part 135 who have not served at least 100 hours as PIC in that type of airplane. Served and logged are not the same in this context, and no matter how the SIC logs his time, he has not served as a PIC until he has completed the training and check rides necessary for certification as a Part 135 PIC.
Approval for single pilot operations with use of an operative approved autopilot system under FAR 135.105 gives an operator an additional option in the conduct of operations. It does not mandate that all future flights be conducted in that manner. The operator can elect to fly trips with two pilots, as is otherwise required for flight in IFR conditions under FAR 135.101, using the second in command instead of the autopilot.
Your second question asks if, under the circumstances given above, the SIC can log time as SIC when the designated pilot in command is flying the aircraft. The answer is yes, as long as the certificate holder is using the SIC as a crewmember instead of exercising the autopilot authorization. In other words, the certificate holder elects not to conduct an IFR flight using the single pilot with a functioning autopilot option, but rather conducts an IFR flight using two qualified pilots. The two pilots are then "required by the regulations under which the flight is conducted", FAR 61.51(c)(3), and the assumption is that the second pilot (SIC) will function as a required crewmember, and SIC time may validly be logged. However, if for some reason another qualified pilot "rides along" and does not function as a crewmember, then second-in-command time may not be validly logged.
This interpretation has been prepared by Arthur E. Jacobson,
Staff Attorney, Operations Law Branch, Regulations and
Enforcement Division; Richard C. Beitel, Manager. It has been
coordinated with the Manager, Air Transportation Division, and
the Manager, General Aviation and Commercial Division, Flight
Standards Service.
We hope this satisfactorily answers your questions.
Sincerely,
/s/ Donald P. Byrne
Assistant Chief Counsel
Regulations and Enforcement Division
It looks to me like you can log SIC time in a king air as long as it is under IFR and 135 with 135 qualified SIC? What do you mean it is logging SIC in a single pilot airplane is not legal time?
You cant just go and log SIC time in any plane just because you have completed a 135 SIC checkride. The op specs must require an SIC for you to log SIC time. If the op specs dont require an SIC you are just another passenger on the revenue legs.
Isn't that what the chief counsel opinion says, that you can still log SIC even if the operator has the ops spec for use of autopilot instead of required SIC for IFR flights? That the operator, with the ops spec approved, now has the ability to use either an SIC or an autopilot.
You could check out ari ben in florida. I have never flown with them but have heard good and bad things about them (there are always crybabies anywhere you go). More good than bad though and the price is well worth a look (like $50somethin bucks an hour). Whatever you decide to do good luck finding the multi time. Have fun and fly safe!
here's the link
http://www.aribenaviator.com/
What the hell good is SIC time in a king air gonna do ya?
The few times I got pressed into pilot services in Part 91 turbine operations, I never even bothered to log it. It was a break from flying 135 in piston twins and I had no responsibilities except to show up and it paid the same...400 bucks a month base, 150 bucks a day, plus expenses and benefits.
It might help get your foot in the door at that operator or it might not. Who's to say.
I know a guy right now that got his ratings all done by dad. After the guy got his multi commercial instrument, dad let him ride shot gun in the King Air B-100. He did get to fly some of the empty legs as PIC. When the corporation sold the plane and dad lost the job, the guy had take a position riding with some rich new pilot in his King Air 300. He never gets to fly that plane. I tried to get him a job with us flying 135 Feeder Operations in Caravans way back when we were looking and management told me they weren't interested. He was offered a position flying Aztecs and Senica's at the place where I flew 135 and 91 pilot services, but he was not willing to take on the job, even though it paid well...I believe he was afraid to do it. Flying winter time, on demand piston operations in the Great Lakes area can be demanding.
I'm not saying it will never do you any good at all...but the only time it would seem to me to be important, is if you are getting PAID for it.
In all honesty...it would take forever to build 500 hours logging empty legs in passenger charters. Most 135 passenger operations are there and back. You might get lucky on the short repo flights, but in most cases that I saw that opportunity, it was a tenth or two at a time.
Building multi time
I guess I should ask an obvious question. Can you ride in your boss' Kingair and fly it on 91 legs? That would be a start.
Do get your MEI. That way you have a tangible credential that you can market. I realize that finding MEI work is tough right now. For that matter, so is finding other work.
Don't stop with your MEI. Shop yourself around to other operators. If you can have a chance to ride in a B90 Kingair and fly it in non-135 operations you can log that time legally. However, as others suggested, be sure you know something about the airplane in case you're asked about it at an interview.
The bottom line, though, is what the others have suggested. What good does Kingair SIC do you when PIC is what you need? Unless it is the situation in which you can serve as PIC when you're flying.
Good luck with your efforts.
