turbopilot
- Mar 22, 2020
I posted the scenario on the CubCrafters forum so we can open this discussion up to a wider audience.
FX3 Wing Fuel Tank Recommendation?
According to the CubCrafters configuration web page at http://cubcrafters.com/carboncub/fx3/configure it outlines 2 x 22gal fuel tanks for a total of 44gal. I've heard through others that this is actually four tanks, 2 x 12 gal inboard tanks with a 10gal outboard of each with an interconnect...forum.cubcrafters.com
Andy seems pretty sharp. But we end up in the same place. There is a big question about the availability of the last 5 gallons in a 44 gallon system. So for planning purposes it is not useable. I sounds like if you ever get into a pinch and need some extra fuel there will be ways to get some of it out. The 24 gallon system has 1 gallon unusable and the belly tank has a 6 once unusable. They way you use a belly tank by cross feeding means you can use it all.
