Medivacer
Putting my time in.
- Dec 9, 2001
You're correct in that beta is everything that isn't the forward, or alpha range. However, in general context, the beta range is typically taken to be a zero thrust range between forward and reverse. Common use differentiates between "just over the gate" when the propeller or power lever controls are just over the gate. Beta is generally taken to be that time when the power lever is moved far enough aft that the fuel control is scheduled to produce increasing power while the propeller is scheduled into a negative angle.
When retarding the power levers to idle in the flight range, you don't control propeller blade angle. The propeller governor does that. In the reverse range, you schedule both power and blade angle with the power levers.
