this Word .doc looks fairly comprehensive
any good?
http://199.60.151.131/documents/program_manual/documents/program-manual-appendix14b - travelair.doc
That is perfect...thanks a bunch
any good?
Great, now can we please let this thread die and move on to Regional posts?
The TravelAir will never die!!! Many fond memories in that thing. So, what do you want to talk about? Skywest hiring? ASA losing flying? Spikey Ipod people? How big E170's are? It wasn't regional related (although the info is for an interview) but it was different, and that is ok with me.
The travel air I fly is a piece of ********************. Oil leaks on the floor of the cockpit, I have had numerous engine failures while at cruise, the door will not remain closed, the heat doesn't work on flights below 30F but works above 40F, Water can always be found in the sump samples even when it hasn't rained in three weeks, inop stickers are plentiful, when something breaks which isn't required it disappears from the airplane, the alternators have to be reset almost every flight, accumulators... what are those, the cockpit lights may or may not work at night, whats that switch do?, yes that smell is normal, trust me it's your first flight in a twin I don't need brakes over here on the right side...... all in all the travel scare is a beautiful beast just needs some loving!
As Mark C. would say. "Theres nothing wrong with the airplane. YOU just need to learn how to fly it."The travel air I fly is a piece of ********************. Oil leaks on the floor of the cockpit, I have had numerous engine failures while at cruise, the door will not remain closed, the heat doesn't work on flights below 30F but works above 40F, Water can always be found in the sump samples even when it hasn't rained in three weeks, inop stickers are plentiful, when something breaks which isn't required it disappears from the airplane, the alternators have to be reset almost every flight, accumulators... what are those, the cockpit lights may or may not work at night, whats that switch do?, yes that smell is normal, trust me it's your first flight in a twin I don't need brakes over here on the right side...... all in all the travel scare is a beautiful beast just needs some loving!
