Beech 1900 D system ?
chperplt
Registered User
Total Time
Anyone know what the Transponder normal/override switch is actually for?
vja217
Richmond, VA
Total Time
300
2nd xpndr
Doesn't that toggle between your primary and secondary transponders?
chperplt
Registered User
Total Time
No, it doesn't do that... There is a switch on the transponder itself that toggles between #1 and #2.
Jack Hass
Active member
Total Time
6000+
believe it toggles the transponder between the captains and Fo's altimeter
chperplt
Registered User
Total Time
Nope.. There is a toggle switch right next to the normal/override switch that does that.
flint4xx
Total Time
10000+
If you have Tcas, I think you can remove it and then operate the transponder via the over-ride since there are some shared components. It has been awhile so don't quote me.
1800 RVR
Sitting reserve...
Total Time
6500
From my understanding, the norm/override switch was for ground ops when they are using surface movement radar. It was to help identify your location. It's been awhile since I've flown the airplane, but I think that is what I remembered. (Then again, maybe the checkairmen were just blowing smoke up my backside...)
fly26
Total Time
5000
If my memory serves me correctly, 1800RVR is right.
With the switch in the Normal position, the transponder only emits a signal in flight. In Override, it emits a continuous signal in flight AND on the ground.
chperplt
Registered User
Total Time
Fly26
You are correct. I got an e-mail from a FlightSafety Beech guru and that's exactly what he said. The normal position will put the transponder in standy-by with weight on wheels.
