EagleRJ said:Correct. Some aircraft have a flight envelope that changes with altitude. Some aircraft that have a moving barber pole are Mach-limited in addition to the knot limitation, and that is what the barber pole is representing.
MauleSkinner said:If you look in your C90 manual, you will probably find something that says Vne is reduced 4 knots for every thousand feet above a certain altitude...no barber pole, but you have to do it manually.
