ATP/Single-Engine Question
RJP
Registered Eye-Poker
A question came up the other day and none of us knew the answer.
If you've got an ATP, does that give you single-engine commercial privileges or does that have to be specified on your license?
Example: ATP rated pilot got ATP in a light twin. The pilot was then offered a job flying a Caravan but never had a single-engine commercial license prior to the ATP. Does the ATP allow for this?
Thanks.
Before everyone jumps in a just gives him the answer, lets do some training here and help teach him how to Find the Answer.....
You and your friends can't come up with what is required so why not break it down into smaller "bites".
1. "What operating certificate is required to operate a single engine aircraft"?
2. "Does a Multi engine ATP allow you to operate a single engine aircraft?
So RJP lets go one step at a time, since this is a "legal" question which CFR covers "Pilot Certification?
Once you figure this out which part of XX CFR allows you to operate ANY aircraft?
If I could (or wanted to) figure it out, why would I post here?
No you are not rated Comm in a SEL, therefore you cna not act as a pilot being compensated for flying a SEL.
Thanks Yip. That's what we figured.
Cheers.
What a waste of your potental talent and everyone elses time.......
Besides if you accept free legal advice - you get what you paid for.
You have no idea. If you had seen my talent, you wouldn't post such blather.
Thanks for the advice, even though you couldn't just answer the question. Would've made the whole thing easier if you had just said "no" instead of trying to play CFI.
Aloha.
Here's a tip: Look on the pilot certificate itself.
It will say, under Certificate: ATP
Under Ratings, it will say AMEL (and type if any)
IF the certificate holder had SE privileges prior to the ATP, it will say: Private (or commercial) privileges ASEL.
It's on the certificate. No need to trust these bozos.
Aloha.
A pilot should know their limitations - you seem to think little of your own talent.
As far as "playing CFI" - I would be willing to bet I was teaching before you were born. So it comes naturally. Not that you care. Maybe you should preface your future questions:
"I'm too lazy to look up and I just do not care so just give me the answer to....."
Then I won't try to "Play" anything.
That's rather pathetic.
You don't want to lift a finger to help yourself...much easier to ask someone else to do it for you. Lack the energy to turn a page or use a search engine, do you? That's sad.
You have no idea. If you had seen my talent, blah, blah, blah, blah, blah...
Looks like we just saw it. Abject laziness and rampant conceit. Sounds like you've got a bad infection, but if you wish to call it talent, by all means, have at it.
That was a tough one, apparently bantied about by some real intellectuals. Intellectuals who are too smart to look it up...look it up on the back of the pilot certificate where it's spelled out and tells you exactly what privileges are accorded. Based on your comments thus far, you don't need an ATP...you need a pacifier and someone to show you how to use it.
The beauty of internet anonymity is that aviation studs like yourself can post pompous replies and spew your useless opinions so everyone can share in your two cents.
JAF, if you can't or won't answer a question, why would you bother to post? How difficult is it to either bite your tongue and not post or just try to answer the question?
AV, you obviously put a lot of effort into your post. Nice work cutting and pasting quotes. I bet your private pilot students are impressed with your skills.
Thanks to both of you CFIs for all your clear, concise answers.
:rolleyes:
Avbug, we are wasting our time on this one. He just does not get it and I doubt he ever will. If he does not get his name in an NTSB report then it will be on the header of an EIR. My fear is that the dumb ones usually kill more than just themselves.
To every one else, knowing how and where to find an "legal" answer will keep you out of more trouble than asking "the guys" is such and such legal.
Bye.
It's tough being hung with your own words, your own quotes, isn't it?
I was rather impressed with JAFI's initial reply. Rather than just spoonfeed your lazy request, he offered to help you find the answer, and did it in an appropriate way. In your rush to celebrate ignorance, you probably failed to realize that he's singly the most qualified person here to answer any such question, for reasons he won't advertise.
Me, I'll slap your face and then slap it again for asking a stupid question, and yes...there's a stupid question. JAFI won't do that. He'll educate you in the process and help you. You're just one of those who can't be helped; the proverbial drowning man who won't take a glass of water. Then there's the whole "You have no idea. If you had seen my talent, you wouldn't post such blather" garbage. JAFI is perhaps one of the humblest participants here, and in this area one of the most uniquely qualified, and you will most definitely not hear him blowing his horn as you just did, oh new-found exhalted chew-toy.
We've seen your talent. Unimpressive, to say the least. Perhaps just underwhelmed might describe it best.
Were I working with any, that would be the least of my concern, or theirs. Their progress and individual needs would certainly be at the forefront of any consideration given them, as it should be. You're impressed enough with yourself for all of us. Good of you to carry that burden.
Clearly to help you find the answer...because let's face it, if after several days you and a group of your peers couldn't devine that multi ATP privileges don't grant single engine privileges...you do need some help in learning how to understand the regulation...and you were getting that help from someone who perhaps understands it in a unique way better than any of the rest of us...too bad you were too dense to take a helping hand when given you.
You're asking the wrong question. You may be better served asking properly. How difficult is it to bite your tongue and receive the help offered you, or just exercise some elementary skills and look it up?
It's so much easier for you to have someone else do it for you, isn't it? Does someone also hold the pen while you try to write, or spoon feed you so you don't spill? You don't have someone doing your breathing for you too, do you? At some point, you're going to have to learn to help yourself.
Perhaps even follow along when someone shows you how.
Do ATP multi engine privileges extend to single engine operations? No. Whereas the privilege is Airline Transport Pilot, Airplane, Multi-Engine, Land...where in that do you find single engine privileges?
Military pilot taking competency to obtain your FAA certification, perhaps? If you're brand new, then you can use all the help you can get. Slapping down a helping hand certainly doesn't help your case, or set any good foot forward, let along a best one.
One might wonder what on earth you would want single engine ATP privileges for in the first place, but whatever floats your boat. Tell the Caravan pilot to take the ATP single as part of his initial checkride, get issued the ATP privileges if that's what he's really craving, and go to work. Or get the commercial...whatever makes him happy. Or you...or whomever. With your level of talent, of which we have no idea...flying a caravan seems far beneath you. We can scarcely but wonder why you don't rejoin society with an open invitation as CEO of any major carrier. Of course it goes without saying, we all wish you the best of luck.
You might try dropping the attitude in your newfound civillian world. You may be the lord high almighty freshly minted ATP warrior, but you're still an entry level pilot. Try acting the part.
SEL ATP easiest check ride I ever took, Grumman Tiger, fixed gear, fixed pitch prop, no cowl flaps, a hold, a NDB, a VOR circle, and a forced landing.
No
And the person STILL does not have SE comm priv. The pilot certificate itself is self-explanatory.
And it this case, I suspect is says:
Airplane Multiengine (land or sea)
Private Privileges
Airplane (SE or ME, Land or Sea)
There is no ambiguity. The actual certificate tells you what you can exercise comm privileges in.
