It all depends on where you're based, and if you live at your base. We work 17 days a month, and most commuters usually bid to work their 17 days in a row so they don't have to commute as often. I live at my base (MIA) and I usually work about 10 days a month. The schedules vary from month to month, and if you're senior enought to hold a line your days off can vary. Some guys work week on, week off, it varies from base to base.
Kalitta is exactly the same way. except the only choice you have is a solid block. I was wondering if Gemini and other heavy lift operators were the same... 17 days on?
