ATCers - Vectors Q?
minitour
So...when y'all'er giving out vectors for an approach (say an ILS and avisual just in case there are differences) do you have a specific pointwhere you bring people in (like...a place where they have to interceptor turn downwind/base/final) or is it just wherever?
Just kinda curious...if two planes are coming in from differentdirections at the same altitude, groundspeed, will reach the same pointat the same time, do you give one a speed restriction or just vectorone inside the other?
No real hurry on the reply...just a curiosity thing. Thanks for any insight.
-mini
In my experience, approach will use whatevertechniquesarenecessarytoachieve the 3 mile separation. Differentaircraftwillintercept thefinal approach course at different points,againdependingon traffic.Just whatever it takes to get a nice"stringofpearls" onfinal. The onlyrestriction is that aircraft oninstrumentapproachesmust be turned-on to final no less than 2 miles(Ithink)prior to theFAF.
If you're a Freight Dog it all happens at the marker and you are told to hold maximum forward airspeed as long as possible. Not sure why but...it's a lot of fun!:)
I have heard controllers speak of 'approach gates' and Ive seen diagrams of such, kind of a funnel to guide the controller in his/her instructions.
Also I've heard of a 'maximum 30deg intercept' for vectors to final, but I've also seen that guideline ignored, so I look forward to controller answers too.
As for the two airplanes at the same speed and distance, I've heard and received 'vectors for spacing' and I'm sure we've all heard 'max forward speed to the marker' or 'maintain at or below 160kts'..
Mini gets the award for most inquisitiveness and best questions.
GravityHater said:
...Mini gets the award for most inquisitiveness and best questions.
Thanks, I just figure if I ask enough questions, some day I'll be just like Cliff...
-mini
Mini,
The "official" rules for instrument approaches are thus:
5-9-1. VECTORS TO FINAL APPROACH COURSE
Except as provided in para 7-4-2, Vectors for Visual Approach, vector arriving aircraft to intercept the final approach course:
a. At least 2 miles outside the approach gate unless one of the following exists:
1. When the reported ceiling is at least 500 feet above the MVA/MIA and the visibility is at least 3 miles (report may be a PIREP if no weather is reported for the airport), aircraft may be vectored to intercept the final approach course closer than 2 miles outside the approach gate but no closer than the approach gate.
2. If specifically requested by the pilot, aircraft may be vectored to intercept the final approach course inside the approach gate but no closer than the final approach fix.
EXCEPTION. Conditions 1 and 2 above do not apply to RNAV aircraft being vectored for a GPS or RNAV approach.
b. For a precision approach, at an altitude not above the glideslope/glidepath or below the minimum glideslope intercept altitude specified on the approach procedure chart.
c. For a nonprecision approach, at an altitude which will allow descent in accordance with the published procedure.
NOTE-
A pilot request for an "evaluation approach," or a "coupled approach," or use of a similar term, indicates the pilot desires the application of subparas a and b.
d. EN ROUTE. The following provisions are required before an aircraft may be vectored to the final approach course:
1. The approach gate and a line (solid or broken), depicting the final approach course starting at or passing through the approach gate and extending away from the airport, be displayed on the radar scope; for a precision approach, the line length shall extend at least the maximum range of the localizer; for a nonprecision approach, the line length shall extend at least 10NM outside the approach gate; and
2. The maximum range selected on the radar display is 150 NM; or
3. An adjacent radar display is set at 125 NM or less, configured for the approach in use, and is utilized for the vector to the final approach course.
4. If unable to comply with subparas 1, 2, or 3 above, issue the clearance in accordance with para 4-8-1, Approach Clearance.
REFERENCE-
FAAO 7110.65, Approach Clearance, Para 4-8-1.
FAAO 7110.65, Final Approach Course Interception, Para 5-9-2.
5-9-2. FINAL APPROACH COURSE INTERCEPTION
a. Assign headings that will permit final approach course interception on a track that does not exceed the interception angles specified in the TBL 5-9-1.
TBL 5-9-1
Approach Course Interception Angle
Distance from interception point to approach gate
Maximum interception angle
Less than 2 miles or triple simultaneous ILS/MLS approaches in use
20 degrees
2 miles or more
30 degrees
(45 degrees for helicopters)
b. If deviations from the final approach course are observed after initial course interception, apply the following:
1. Outside the approach gate: apply procedures in accordance with subpara a, if necessary, vector the aircraft for another approach.
2. Inside the approach gate: inform the pilot of the aircraft's position and ask intentions.
PHRASEOLOGY-
(Ident) (distance) MILE(S) FROM THE AIRPORT, (distance) MILE(S) RIGHT/LEFT OF COURSE, SAY INTENTIONS.
NOTE-
The intent is to provide for a track course intercept angle judged by the controller to be no greater than specified by this procedure.
REFERENCE-
FAAO 7110.65, Chapter 5, Section 9, Radar Arrivals, and Section 10, Radar Approaches- Terminal.
c. EN ROUTE. When using a radar scope range above 125 NM, the controller shall solicit and receive a pilot report that the aircraft is established on the final approach course. If the pilot has not reported established by the final approach gate, inform the pilot of his/her observed position and ask intentions.
I dare say that these rules do get bent a bit when trying to fill a final.
When vectoring for a Visual, the reported ceiling must be at least 500" above the lowest MVA. However, if we're vectoring for any type approach, and the WX is at least VFR, if the pilot requests a Visual and has the field or preceeding traffic in sight, we can still clear him. It just has to be 500' above for the controller to initiate a vector.
Some airlines, as a general rule, don't like turning final closer than the FAF, especially at night, even on a visual. That doesn't mean there aren't exceptions. Often they'll turn closer for me in the day if I ask them in advance before I try stuffing them in on a 2 mile base.
Now, here's your homework: If there's a Cessna doing 80 kts IAS on ILS final 6 miles out, and a B737-800 behind doing 200 kts IAS; and both have a 20 kt headwind, how far behind the Cessna does the B738 have to be in order to have 3 miles spacing at the Cessna's touchdown?
(assume the Boeing will stay at 200 kts until the 3 mile final.)
...15?
Vector4fun said:
Now, here's your homework: If there's a Cessna doing 80ktsIASonILSfinal 6 miles out, and a B737-800 behind doing 200ktsIAS;andbothhave a 20 kt headwind, how far behind the Cessna doestheB738havetobe in order to have 3 miles spacing at the Cessna'stouchdown?
My guess is 15.
I would say 21 miles. With the headwind, the 172 is doing 1 mile/min and the 73 is doing 3 miles/min. In the six minutes it takes the the 172 to land the 73 has covered 18 miles. Therefore to be spaced 3 miles at touchdown, the 73 has to be 21 miles in trail.
What do I win Johnny?
Nothing.
The 738 is traveling at 3 miles/minute. The Cessna is traveling at 1 mile/minute.
It'll take the Cessna 6 minutes to land, in that time the 738 will have traveled 18NM...if it started out 15NM behind the Cessna 6NM from the runway, it'll have 3NM left to travel when the Cessna touches down.
...I think....:D
Vector4fun said:
...Now, here's your homework: If there's a Cessnadoing 80 kts IAS on ILS final 6 miles out, and a B737-800 behind doing200 kts IAS; and both have a 20 kt headwind, how far behind the Cessnadoes the B738 have to be in order to have 3 miles spacing at theCessna's touchdown?
uhhhh....
hmm..maybe I will stay on this side of the deal rather than attempt toget on your side. I sometimes f*ck up when I have to figure out adescent rate/checkpoint...I couldn't imagine doing that with 150 planeson vectors for the same approach spaced out all over theplace...incredible...
Anywho, thanks for the incredibly detailed info there. Kinda neat to see how "the dark side" works sometimes...
Thanks!
-mini
mattpilot said:
1 mile a second? man.. Must be one of those french built cessnas... the F-172s, eh? ;)
Nah...the French built Cessnas have 6 engines and 12 seating decks...you know...bigger is better.
-mini
21 miles from the runway, or 15 behind the Cessna. Now consider, when I'm working finals, my airspace only extends 22 miles from the runway. If I have downwinds extending beyond 20 miles, I'm supposed to start making pointouts to my fellow "feeder" controllers, and I'm in the protected airspace for arrivals and departures off two satellite fields.
So, that's why the controller is hammering you to keep the speed up in that Cessna, because just an extra 20 kts on your part means about 4 miles shaved off the downwind for the controller. Also, turning the Cessna on at the app gate, rather than two miles outside of it, saves at least twice that (4 miles) for the Boeing behind. (unless it's a light B757, because they fly final as slow as Cessnas anyway....)
