From someone with Asian experience.
Probably not politically correct, but he has a point.
Passed as received. I'm NOT the author, just the messenger.
No comment.
What happened to the B-777 flight is quite simple.
1. They are Asian.
2. They are Asian .
3. They are Asian.
They cannot, nor will they ever be capable of a visual approach. Not in their skill set. They are totally directed in how to do every thing. Free thought is not allowed. Add the culture; not losing face, and the flight was doomed as soon as they were cleared for the visual.
The landing speed of 137 kts better know as Vref is 1.3 above stall. All airplanes fly this speed. So dividing 137 by 1.3 = 105 or Vs (stall). Stick shaker is 1.07 Vs or in this case 112 Kts. So they slowed 25 kts or 25x1.151=28.7 Mph.
When they finally play the cockpit voice recorder, you will find nobody said a word as the aircraft slowed. NOBODY! That is because to do so would have caused a loss of face. Many problems.
It does not matter at all the guy only had 43 hrs in type. Not at all.
He had plenty of time in 74's. An airplane is an airplane. They ALL fly the same way. (Except the piece of junk airbus)
I have watched time after time Asian carriers cleared for visual approaches miss the runway, either to high or get low and miss. I have gotten on the radio and have told the controller, send them out for the ILS or they are not landing today. Needless to say have been in trouble many times because of it.
The fact they waited til 1 or two kts above stick shaker to say something says volumes about the cockpit culture.
When I was a check airman, doing the exact thing he was doing, I allowed abt 5 kts either side of Vref before correcting. You have to see if they will correct. Part of the learning curve. Was more tolerant if fast than slow. If they did not correct the situation in a timely manner than I did. It's your Job!!
The fact that all four pilots in that cockpit allowed that aircraft to slow to stick shaker and say nothing is beyond belief by western culture standards!!!
They, the Faa and NTSB will dance around this fact, not want to offend anyone. This will also be tragic.
So if the airline sounds Asian DO NOT get on it!!!
We have been discussing over the last couple of years, that pilots being trained today with all the automation, lack basic flying skills. Both western and foreign.
We see it in the Sims every day. It is a guarantee , if they are Asian, and you take away the automation, it will not end well. Never does. But, by the same token, we have just as much failure with the new breed of American pilots.
Have had many a discussion with our FAA reps and they know it to.
This problem will only get worse over time. I would take a train but an Airplane would probably crash into it.
Have a great day!
Dude get real. They both had heavy Boeing experience. You saying theyve just been lucky?? A non Asian pulled up during a stall a few years ago and killed a bunch of people in New York. What do you have to say to that? He's white?
Cause aside, after seeing the video of the impact and cartwheel, you have to be impressed with the way the 777 held up. Well done Boeing.
It has nothing to do with race, but it does have a lot with culture and tradition. Just an example, Bombardier in Montreal has special policies when it comes to Japanese customers. That because it had cases of harakiri for not passing a check ride.
I've been flying in Japan for the past 7 years and you find all kinds, the majority are very good airmen but there are some that are not that good, but then again, I can say the same about the British, Australians, Americans, South Americans, Europeans.......! This whole conversation about the reasons being that they are "Asians" it's just plain ridiculous, there are good and bad airman represented in every continent, after all, in the good'ol USA we have planted enough metal into the ground for stupidity haven't we? I don't think that we have the right to point fingers.
You are correct Sir. That is the reason why I gave the 747-400 driver example.
However, being almost a victimless accident, it sounds a bit funny. My understanding is that the PF was an Airbuss driver. That could be taken in consideration too. 777 is a notch longer than A320 and being kind of new on 777 he didn't have enough time to adjust to the new iron.
