This aint Amtrak. DL has to make money consistantly to eventually buy bigger airplanes to compete with the likes of your company, Emirates. You have to have big, NEW, airplanes to compete on Global scale.
Bye Bye---General Lee
I didn't say there was anything wrong with Delta making money.
Do you forget that we have to compete with the likes of your company, Delta, as well? Nobody stopped Delta from purchasing new and larger aircraft instead of more RJ's.
Delta uses its 5th freedom rights out of NRT.....How would you feel if Emirates created a hub in LAX or ATL when Delta is doing the same thing in someone else's backyard. Should the government step in to protect Delta?
Also, when you assumed that Emirates was getting cheap fuel in Dubai, which is not the case, you were on here complaining about it......BUT....now that Delta has purchased a refinery and may reap the benefits of some cheaper fuel in the Northeast, I don't hear you complaining about an "unfair" advantage.
Interesting times.
