Are turbo-props considered high perf?
CrazyErnie
roger dodger
I was wondering if turbo-props are considered high perf (or complex for that matter) if they are rated over 200 SHP? I don't know of anything that disqualifies them just because they're not recip engines, but maybe somebody could enlighten me. For the discussion, consider the aircraft to be over 12,500 lbs.
-Thanks
The regulation (FAR 61.31) simply says "Horsepower" -- not Brake Horsepower (piston) nor Shaft Horsepower (turboprop). So yes, if your turboprop has an engine with more than 200shp, it's high-performance. And assuming it has flaps, retractable gear, and a controllable prop, it's complex as well.
complex airplane: an airplane that has a retractable landing gear, flaps, and a controllable pitch propeller; or, in the case of a seaplane, flaps and a controllable pitch propeller.
Complex has no reference to engine type or power. Caravans and Twin Otters are two examples of non-complex turboprops. BTW, why the stipulation about being over 12,500?
Mostly a question of curiosity. I am familiar with all the above mentioned FARs, but I wasn't sure if there was anything out there disqualifying turbo-props since it would be hard to find one under 200 SHP. Same with the complex airplane definition. The majority of turbo-props are going to be complex airplanes. I wonder how many captains out there have gotten their ATPs, but never been endorsed for a high perf. aircraft. The weight was tossed in there just in case it made a difference that the aircraft was considered a large aircraft.
Thanks for the clarification.
I thought part of the Definition of "Complex" was all that stuff, OR something that is Turbine powered. Have to go find my old FAR/AIM book.
When I got my ATP, I didn't have complex or high performance endorsements, as they weren't required when I started flying complex and high performance aircraft. The definitions and regulations regarding them have changed somewhat over the years, too...what is "complex" or "high performance" today is different than what it was just a few years ago.
I still don't have a "tailwheel" endorsement, even though I stay fairly current in conventional gear airplanes.
Yellowbird said:
Just curious: are there many turboprops of 200 SHP or less?
I'm curious too. The smallest I've seen are 550 SHP on Beechcraft. Perhaps there's a smaller one on a Malibu? At any rate I'm sure it would far exeed 200 SHP.
Would that mean that a jet would be considered complex even though it does not have propellers? I have been asking some people lately, but have been getting a myriad of resposes.
You fly a jet or large aircraft on a type-rating which supercedes the need for high performance, complex, or even a taildragger endorsement in the case of the DC-3.
FAR 61.31:
(e) Additional training required for operating complex airplanes. (1) Except as provided in paragraph (e)(2) of this section, no person may act as pilot in command of a complex airplane (an airplane that has a retractable landing gear, flaps, and a controllable pitch propeller; or, in the case of a seaplane, flaps and a controllable pitch propeller), unless the person has—
(i) Received and logged ground and flight training from an authorized instructor in a complex airplane, or in a flight simulator or flight training device that is representative of a complex airplane, and has been found proficient in the operation and systems of the airplane; and
(ii) Received a one-time endorsement in the pilot's logbook from an authorized instructor who certifies the person is proficient to operate a complex airplane.
(2) The training and endorsement required by paragraph (e)(1) of this section is not required if the person has logged flight time as pilot in command of a complex airplane, or in a flight simulator or flight training device that is representative of a complex airplane prior to August 4, 1997.
(f) Additional training required for operating high-performance airplanes. (1) Except as provided in paragraph (f)(2) of this section, no person may act as pilot in command of a high-performance airplane (an airplane with an engine of more than 200 horsepower), unless the person has—
(i) Received and logged ground and flight training from an authorized instructor in a high-performance airplane, or in a flight simulator or flight training device that is representative of a high-performance airplane, and has been found proficient in the operation and systems of the airplane; and
(ii) Received a one-time endorsement in the pilot's logbook from an authorized instructor who certifies the person is proficient to operate a high-performance airplane.
(2) The training and endorsement required by paragraph (f)(1) of this section is not required if the person has logged flight time as pilot in command of a high-performance airplane, or in a flight simulator or flight training device that is representative of a high-performance airplane prior to August 4, 1997.
(g) Additional training required for operating pressurized aircraft capable of operating at high altitudes. (1) Except as provided in paragraph (g)(3) of this section, no person may act as pilot in command of a pressurized aircraft (an aircraft that has a service ceiling or maximum operating altitude, whichever is lower, above 25,000 feet MSL), unless that person has received and logged ground training from an authorized instructor and obtained an endorsement in the person's logbook or training record from an authorized instructor who certifies the person has satisfactorily accomplished the ground training. The ground training must include at least the following subjects:
(i) High-altitude aerodynamics and meteorology;
(ii) Respiration;
(iii) Effects, symptoms, and causes of hypoxia and any other high-altitude sickness;
(iv) Duration of consciousness without supplemental oxygen;
(v) Effects of prolonged usage of supplemental oxygen;
(vi) Causes and effects of gas expansion and gas bubble formation;
(vii) Preventive measures for eliminating gas expansion, gas bubble formation, and high-altitude sickness;
(viii) Physical phenomena and incidents of decompression; and
(ix) Any other physiological aspects of high-altitude flight.
(2) Except as provided in paragraph (g)(3) of this section, no person may act as pilot in command of a pressurized aircraft unless that person has received and logged training from an authorized instructor in a pressurized aircraft, or in a flight simulator or flight training device that is representative of a pressurized aircraft, and obtained an endorsement in the person's logbook or training record from an authorized instructor who found the person proficient in the operation of a pressurized aircraft. The flight training must include at least the following subjects:
(i) Normal cruise flight operations while operating above 25,000 feet MSL;
(ii) Proper emergency procedures for simulated rapid decompression without actually depressurizing the aircraft; and
(iii) Emergency descent procedures.
(3) The training and endorsement required by paragraphs (g)(1) and (g)(2) of this section are not required if that person can document satisfactory accomplishment of any of the following in a pressurized aircraft, or in a flight simulator or flight training device that is representative of a pressurized aircraft:
I don't see any provision for waiving the conventional gear endorsement with granting a type rating for a tailwheel airplane.
(i) Additional training required for operating tailwheel airplanes.
(1) Except as provided in paragraph (i)(2) of this section, no person may act as pilot in command of a tailwheel airplane unless that person has received and logged flight training from an authorized instructor in a tailwheel airplane and received an endorsement in the person's logbook from an authorized instructor who found the person proficient in the operation of a tailwheel airplane. The flight training must include at least the following maneuvers and procedures:
(i) Normal and crosswind takeoffs and landings;
(ii) Wheel landings (unless the manufacturer has recommended against such landings); and
(iii) Go-around procedures.
(2) The training and endorsement required by paragraph (i)(1) of this section is not required if the person logged pilot-in-command time in a tailwheel airplane before April 15, 1991.
No, there is no such exemption from the definition of complex. A turboprop (with retractable gear and flaps) is complex. A jet is not.
Does that also supercede the need for a high-altitude endorsement?
This may help or confuse...I believe at one time,the high performance/ complex were the same sign off. However, back in the mid 90's the FAA changed the requirement and made it into 2 distinct signoffs/endorsements. This had to do with older aircraft having over 200 hp but lacked retract. gear, ect...The change occurred due to the requirements to get your commercial license (Specific aircraft requirements) which stipulates a "complex" aircraft, Example; Cessna 172RG vs C206 Non-retract.
In terms of the Jet, it's complex by far but more important, requires a type rating which includes a high altitude signoff per the training and type requirement. Also, it meets and exceeds both endorsements.
Apologize if you already covered this....hopefully it helped rather than hindered.
I've been to recurrent on a couple of different airplanes where I've talked with guys getting their types. In a couple of occassions, they needed an extra class to comply with the high-altitude endorsment requirement. It makes sense - the type-rating is basically a systems course and you train to proficiency on procedures. Very little, if anything, is ever mentioned regarding the physiology of high-altitude flight.
LS
When I got my first Type, I had to take a class on high altitude ops. and get endorsed as a "pre-requirement" for the type. That was 10 years agao, things might have changed.
Check out www.innodyn.com pretty sweet little deal, I think they go as low as 165hp to 255hp...
So I am confused. Is jet time complex and/or high performance time or not?
High performance or complex time/sign off is for the purpose of a rating. Warning: The FAR'S that most pilots used are not the same as the FAR'S the FAA uses. Part 61 is for AIRMEN CERTIFICATION.
What about for the purpose of logging. Is a jet complex?
Why would you want to log 'complex' time? Who cares once you you have the sign off or type rating?
http://www.amtjets.com/gallery_real_plain.html
Does this one qualify? A jet powered Cri Cri. It is a turbo jet....Does it require a type rating? :)
Original design has 2- 8hp chain saw motors. This guy gave it a bit more.
I have seen somewhere a pic of someone that put 2 small turbo props on the thing. I am sure that they were not any bigger than these little jets. But have not been able to find it.
