BoDEAN said:The aircraft tail number, that doesn't go under flight number. Is there a blank to put that in? Ill take a look at the pdf
Prop2Jet said:Make sure you put PF or PNF Nit etc... or it will not sync right for your log book. Before you snyc go through it again and make sure your data is correct. If not and you sync you will have to delete the logbook entry and correct it on the pda then resync it.
Remember to ender the PF or PNF or if you are a Captain enter CA-PF/PNF/Day/Nit
Enjoy!
BoDEAN said:Not sure what to put in there if you are deadheading.
