BoDEAN said:So by previously purchasing logbookpro for the PDA, that was a waste, as I should have gotten this app instead?
Prop2Jet said:Just make SURE you have a Windows Xp system and an already working Palm or Pocket PC. Be aware if your computer has XP ,media center edition, your new palm series will not work on it. You will have to get XP pro or home edition for the new PALMS (they don't support XP-MCE)
PM and I will give you a referal code for 10 bucks off! I don't get anything but the same discount and I already have the stuff so the 10$ is useless for me!
Prop2Jet said:Ok all here is a $10 discount for you if you want to purchase any Logbook Pro solution. I have used NC Software for years and entrust my times with Neil and his staff. Check his page out at WWW.LogbookPro.com
Hello All!
Here is your code for your $10 savings coupon: REFCODE-l-246
Please enter the code in the appropriate location when you E-checkout.
I have found their software to be very easy to use and great for 121 time tracking.
Good luck and I wish you the best in your endeavors,
V/R
P2J
SizzleChest said:Is anybody here using SkyGuide for pocketPC???
CoATP said:Works great but there is a problem when you have "stand-ups", "highspeeds", "CDO" [whatever you call them] on following days as it does not do two trips on a single dayh.
BoDEAN said:Got some questions with the program:
1. Pay rate. What do we put in there? Our pay rate per hour? Does this take into effect a 75 hr minimum pay for being on reserve?
BoDEAN said:2. Where do we put in the Aircraft Number for the flight?
BoDEAN said:3. Why is there an option to input a "deadhead leg?"
No, deadheading can be part of your duty period.BoDEAN said:Is this for rest requirements?
Me either. Welcome to Airline flying.BoDEAN said:I don't know anyone who puts a deadhead leg in their logbook.
Yes.BoDEAN said:4. If we are flying reserve, do we select Reserve instead of block from the dropdown box?
BoDEAN said:5. How does this program compute duty times based on weather delays? I believe our company (American Eagle) can extend you to 16 hr duty day if you have delays due to weather.
