The local news reported a "near miss" of sorts at FLL either today or yesterday. Interviewed passenger said his plane touched down then climbed away. Wonder if it was a runway incursion or somthing else.
NTSB Identification: OPS07IA006A
Scheduled 14 CFR Part 121: Air Carrier operation of DELTA AIRLINES INC DFW BASE MAINTENANCE
Incident occurred Wednesday, July 11, 2007 in Fort Lauderdale, FL
Aircraft: Boeing 757-232, registration: N6714Q
Injuries: 172 Uninjured.
This is preliminary information, subject to change, and may contain errors. Any errors in this report will be corrected when the final report has been completed.
On July 11, 2007, at 1437 Eastern daylight time a runway incursion occurred at the Fort Lauderdale-Hollywood Airport, (FLL), Fort Lauderdale, Florida between United (UAL) flight 1544, an A-320 and Delta Airlines (DAL) flight 1489, a Boeing 757. The incident occurred in day visual flight rules conditions, visibility 10 miles, scattered clouds at 4,800 feet.
The FLL ground controller (GC) instructed UAL1544 to taxi to runway 9L via taxiways T7, D, and B. As the flight was taxiing on taxiway D near runway 9L, the tower local controller (LC) noticed the airplane was going too fast to hold short of the runway. LC told the GC to tell UAL to stop. The GC said "UAL 1544 stop, stop, stop". The crew stopped on runway 9L, 30 feet from the centerline.
DAL1489 was inbound for landing on runway 9L when LC determined that UAL1544 was not going to hold short of the runway. LC instructed DAL1489 to go around. When the crew received the instruction, the main landing gear was on the ground. According to the crew statement, they noted the urgency in the controller's voice so they knew they had to get the aircraft airborne. FAA reported DAL1489 flew over UAL1544 by less than 100 feet.
According to the FAA, the UAL crew stated they missed the turn onto taxiway B.
FLL air traffic control tower is not equipped with either AMASS or ASDE-X. All airport lighting was functioning normally.
In my view, this sort of incident is as much an airport and facilities issue as it is a crew deficiency.
In Europe, I generally follow a row of green lights to a row of flashing red lights running perpendicular to my direction of taxi. The meaning of the red lights leaves little to be interpreted.
Unfortunately, this experience occurs all too infrequently in the US.
Improving and standardizing domestic airport markings and installing current technology devices for aircraft surface control would go a long way toward improving safety for us and our passengers.
