sandslob
Active member
- Oct 16, 2004
If you plan on using the handheld transceiver as a flight bag backup, I would definately recommend an alkaline battery pack as opposed to the normal nicad batteries. Nicads will discharge over time and you may not have battery power when you need it. The shelf life of alkaline batteries is measured in years.sandslob said:I want to buy a decent transceiver. Any recommendations?
Lead Sled said:If you plan on using the handheld transceiver as a flight bag backup, I would definately recommend an alkaline battery pack as opposed to the normal nicad batteries. Nicads will discharge over time and you may not have battery power when you need it. The shelf life of alkaline batteries is measured in years.
'Sled
