Any suggestions?
bart-
Ouch. I will take those numbers into account. But, you are correct, I have not done my FAR homework yet. What I've done so far is basically sit and think about it, and do a good bit of typing. I will PM you with another question about a specific operation (when I get home).
RichardFitzwell-
Would you say that your operation gets "allot" of business?
FAR homework in progress. I've read 119 and 135 and now seek further understanding. Please excuse any silly questions.
If the Director of operations has the correct qualifications, he/she can be utilized as a PIC correct?
Can, or has anyone heard of, a repair facility be used in a contract agreement for maintenance requirements? If so, can an amendment to the Certificate be granted to remove the Director of maintenance requirement? 119.41 maybe?
If you are looking for a one airplane one pilot 135 outfit, that is easier to start. When I say easier, I use that term loosly.
I just spoke with a gentleman yesterday that owns and runs a flight school and already has an airplane to use for part 135. He has been a D.O. for a multiplane 135 outfit in a previous job and has been involved in setting up 2 different 135 certificates. He did the initial inquery with the FAA at the FSDO that would cover his operation. Their response? It will be May before they will even speak with him for the initial "135 information meeting" He explained that he had a large amount of 135 experience etc etc..... Their response? "Alot has changed in past couple of years, cannot meet with you until May"
He expects to be able to fly his first 135 trip in the plane about November of 2006.
KeroseneSnorter-
Wow. Thank you for the info. So that aircraft will just sit in wait until the end od 2006? Knowing his current estimated wait time, is it shorter considering he has an aircraft that is ready to go?
You mentioned one of my current debates. It seems that starting with only one aircraft would be considerably easier than starting with 2 or 3. I'm looking into how difficult expansion would be (Hiring the correct people and getting more planes added to the certificate) once business picked up. Or would it be better to get the multi-plane work done up front.
Correct.
Also, check your PM's for an answer to a question you had earlier in the thread.
s0ldier93 said:
KeroseneSnorter-
Right now he is renting and instructing in the airplane, so it is making a little income.
Last time I dealt with 135 you could run one airplane with one pilot on the certificate and that eliminated a lot of the paperwork required. (some of the training manuals etc.) That has been a few years ago so things may have changed though. There is a sample 135 certificate filing that you can download from the FAA's web site that will give you an idea of what to expect. The sample or "template" is for one plane with one pilot and bare minimum IFR certification. ie. basic ifr requirements of 1 mile vis to take off and the like. we all know that to make money you really need to have more realistic IFR criteria for reduced T/O mins and the like, but that has to all be applied for on an individual basis and have the appropriate training manuals and ops specs approved to do it. Have plenty of paper availible in the printer when you print it up. (and a spare toner for the printer!!!!) it is long.
The feds also have a "quick start" cd now that you just enter your company name in and it inserts your info in all the correct places in your 135 app and op specs. Expect to have to rewrite sections of this several time even though you use the "quick start" info.
Of course you could go the route that someone else suggested and buy an already active 135 certificate. I am sure that you could find many for sale right now given the market. A lot more money but would get you up and running quicker (Notice I did not say quick! :) )
I have to agree with the other posters about airplane choice. Go with a twin. Baron at the minimum, but a cabin class twin would be best. Most companies will not put their people on a single engine airplane anymore. More and more of them require their people to be on a turbine aircraft as well.
Personally I think that there are some niche markets that would bring in customers for a little 135 operation with a little hustle and out of the box thinking. I would not try the standard business passenger 135 outfit in my neck of the woods, King Airs are a dime a dozen around here for charter. If I ever come across a pile of money that I feel like throwing away, I may try some of my ideas.
How do you make a small fortune in aviation?.....................
Start with a big one right? As for aircraft choises, I'm thinking C-402/414/421. I've even seen a few turbine ones one www.aso.com.
I'll go search the FAA site for that guide. Thank you for the info.
All 3xx's and 4xx's? Glad I decided against picking up that 310 for personal use.
The 300 series is fine. They are not part of the NPRM.
All the 400's except the 421 are named in the NPRM for the AD. And it appears to be very expensive. I do not know why the 421 is not listed as being affected, perhaps a design difference in the spar. At any rate, you are still safe buying a 310 or 340..........at least for now :)
I would check with the feds at your FSDO before buying a turbine conversion for your 135 ops. I don't know, but I have a feeling that they will not allow an airplane on 135 that has been that heavily modified. I'm sure that some of the conversions will work with the FAA, but given the pain in the rear it is just to get a factory original airplane approved for 135 and added to your certificate, I have my doubts that many of the piston to turbine conversions will pass the FAA Maint. inspection. Pretty much unless it is certified from the factory, the feds are a little squemish about putting paying passengers on it. The only exception I can think of is the Convair 580 and 660. But I am pretty sure when Convair did the conversions, they had a new type certificate done for the airplanes. (Plus it was 40+ years ago!!)
Maybe someone else on here has come across the turbine conversion issue for 135 and can give you more info.
